Author Topic: How much play should the front sprocket have?  (Read 1566 times)
Offline Scott S
« on: December 26, 2011, 04:35:13 AM »
 I have a '76 CB550 engine on the stand and the front sprocket has some play on the output shaft. I guess you'd call it lateral or side to side play, almost like a washer or spacer is missing, but everything is there.
 Is it supposed to fit tight or is a little movement OK?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Eddie
Re: How much play should the front sprocket have?
« Reply #1 on: December 26, 2011, 04:46:17 AM »
my 550 has a little movement as well... not sure if the is a min /max/ runout measurement.
« Reply #2 on: December 26, 2011, 05:09:17 AM »
They are designed to allow movement. The two 6mm bolts attach the retainer to the sprocket and the retainer"locates" in the groove on the countershaft. This is a good thing as it helps keep sprockets aligned.
Offline Scott S
« Reply #3 on: December 26, 2011, 05:27:02 AM »
 Thanks! That's good to know.
'71 CB500 K0
'81 Yamaha XS650
Offline Kong
« Reply #4 on: December 26, 2011, 01:03:35 PM »
Count yourself lucky to have some play in it.  One of mine welded itself up tight to the shaft and I ended up having to take a cutoff wheel and chop the sprocket off the shaft in pieces.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
