Author Topic: Project "Evolution" 78' CB750K... the morphing continues...  (Read 113433 times)
Re: Project "Evolution" 78' CB750K... Update!
« Reply #175 on: October 27, 2016, 03:57:55 PM »
 Picts to follow... stay tuned!  8)
Holy crap, Wilbur! How long do we need to stay tuned??!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #176 on: October 27, 2016, 07:18:53 PM »
Until now...
New (to me) Dyna DRL-200 safely stowed in the tool rev limiter tray:
All wired up:
Safely snuggled in some high density foam:
 8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: Project "Evolution" 78' CB750K... Further evolved...
« Reply #177 on: March 19, 2017, 06:26:27 PM »
Dropped the oil pan today and found the rest of the wayward friction material from the friction disks that failed during test-n-tune two weeks ago:
Also addressed the weak link that reared its ugly head in the form of a failed glass fuse before half track in round three last weekend:
That's right, you are not seeing things. I added another 15A circuit dedicated strictly to igniting the fuel/air mixture. While I was at it I added a couple relays to take the load off the ignition switch. EZPZ  ;)
No more failed glass fuses for me!  8)
« Last Edit: March 19, 2017, 08:19:39 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #178 on: March 20, 2017, 07:27:18 AM »
Hey Wilbur...looks good.  Debating switching fuse blacks too, where did you source them, Hondaman?
Whens the next race?
Offline Rnobx67
  • "failure is an option here."
« Reply #179 on: March 20, 2017, 07:45:25 AM »
Want to keep an eye on your post. Amazing job done
« Reply #180 on: March 20, 2017, 07:57:01 AM »
The fuse block I used from here:
http://www.wiringproducts.com/4-circuit-raised-ato-atc-fuse-block.html
It uses 1/4" male spade connections on the backside. I had a melted fusebox in the parts bin that I harvested the harness pigtail from. New Vintage Connections connectors for the fusebox connections on the freshly trimmed wires and the other end plugs right in to the stock harness. The holes are almost exactly the same as the stock fusebox if you orient it horizontally. This stuck out a little far for my taste so I made a bracket to recess it in about 3/8" which uses the stock mounting holes and orients the new fuse block vertically as well.
Next race in Valdosta in April... coming soon!  8)
TAMTF...
Wilbur
Projects:
« Reply #181 on: March 20, 2017, 08:14:55 AM »
Same company supplies a 6-fuse block.  http://www.wiringproducts.com/6-circuit-ato-atc-fuse-block.html
It's a good idea in that it allows you to carry 2 spare fuses (just in case).
« Reply #182 on: March 20, 2017, 08:53:27 AM »
I ordered a couple of those as well, but the side connections make this a rather large assembly when wired up. It can be done, just requires more real estate.
TAMTF...
Wilbur
Projects:
« Reply #183 on: March 20, 2017, 02:41:25 PM »
Good info...thanks
« Reply #184 on: March 20, 2017, 05:08:47 PM »
Good info...thanks
If you use the same (or similar) fuse block, I can post a pdf pattern for the bracket if you like.
TAMTF...
Wilbur
Projects:
Re: Project "Evolution" 78' CB750K... the morphing continues...
« Reply #185 on: November 03, 2018, 07:35:33 PM »
Well, I figured a drag bike should at least be sporting drag pipes, especially since I've had a set hanging from the rafters for longer than I can remember. While I was at it I went ahead and sprung for a set of Steel Dragon's velocity stacks. Now I typically refrain from putting form ahead of function, but velocity stacks are just too dang cool... and their name even sounds fast!
I got schooled on drag pipe installation as well. Turns out the left side pipes won't clear the kickstand spring (at least on a K8 anyway). I had to move the spring from the front (outboard side) of the kickstand to the back (inboard side):
Even after lowering the front by 2" and the rear by about 1-1/2" you'll notice that the center stand only lifts the rear by about 1/2". That's because the centerstand is from a GL1100, and it's a direct bolt on. Just had to weld on a spring hook since the GL spring hook was on the wrong side. The stock 750 centerstand would hold the rear wheel almost 4" off the ground. I had to roll it up on two 2x4's just to use it. With the GL centerstand I can roll the bike up with just one hand on the bar while stepping on the lever.  8)
« Last Edit: September 23, 2019, 06:51:01 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
« Reply #186 on: November 04, 2018, 07:29:48 AM »
Pics aren't showing, Wilbur--- :'(
Hmmm... I've attached the photos to the previous post to see if that will coax a connection to Google-fu. I have seen sporadic broken links to the Google photos but it will usually resolve itself eventually.  ???
TAMTF...
Wilbur
Projects:
« Reply #187 on: November 04, 2018, 12:35:12 PM »
Looks good Wilber!  Should drop your ET's by at least .5 sec!!
« Reply #188 on: November 04, 2018, 12:46:30 PM »
whoa there Steve-o!  half a second would would be a quite significant improvement!  I never figured on those "drag" pipes actually having any performance improvement whatsoever.  But then I always ditched 'em for ground clearance reasons...not an issue on the strip.  Curious if you did any street tests after installation or any jetting changes?
« Reply #189 on: November 04, 2018, 01:44:30 PM »
LOL! Don't know if there will be any performance gain, simply an indulgence. I'll likely sync the carbs, do some plug chops, and index the plugs next weekend.  8)
TAMTF...
Wilbur
Projects:
« Reply #190 on: November 04, 2018, 04:30:30 PM »
Ha.... wasn't being serious about the ET times but I bet it will feel more powerful on the butt dyno!
« Reply #191 on: November 04, 2018, 06:36:02 PM »
That's the only one that matters!  8)
TAMTF...
Wilbur
Projects:
« Reply #192 on: November 04, 2018, 06:41:48 PM »
  Back to your jetting, we had jr dragsters and when we went from stock stroke to the +.563 stroker cranks we actually needed a smaller main jet. The extra pull on the intake made the carburetor work better with the components we already had. I ran a 30mm lectron, most guys had a 28mm mikuni.
