Picts to follow... stay tuned!
Quote from: madmtnmotors on October 22, 2016, 01:21:47 PM Picts to follow... stay tuned! Holy crap, Wilbur! How long do we need to stay tuned??!
Same company supplies a 6-fuse block. http://www.wiringproducts.com/6-circuit-ato-atc-fuse-block.htmlIt's a good idea in that it allows you to carry 2 spare fuses (just in case).
The fuse block I used from here:http://www.wiringproducts.com/4-circuit-raised-ato-atc-fuse-block.htmlIt uses 1/4" male spade connections on the backside. I had a melted fusebox in the parts bin that I harvested the harness pigtail from. New Vintage Connections connectors for the fusebox connections on the freshly trimmed wires and the other end plugs right in to the stock harness. The holes are almost exactly the same as the stock fusebox if you orient it horizontally. This stuck out a little far for my taste so I made a bracket to recess it in about 3/8" which uses the stock mounting holes and orients the new fuse block vertically as well.Next race in Valdosta in April... coming soon!
Quote from: madmtnmotors on March 20, 2017, 07:57:01 AMThe fuse block I used from here:http://www.wiringproducts.com/4-circuit-raised-ato-atc-fuse-block.htmlIt uses 1/4" male spade connections on the backside. I had a melted fusebox in the parts bin that I harvested the harness pigtail from. New Vintage Connections connectors for the fusebox connections on the freshly trimmed wires and the other end plugs right in to the stock harness. The holes are almost exactly the same as the stock fusebox if you orient it horizontally. This stuck out a little far for my taste so I made a bracket to recess it in about 3/8" which uses the stock mounting holes and orients the new fuse block vertically as well.Next race in Valdosta in April... coming soon! Good info...thanks
Pics aren't showing, Wilbur---
Looks good Wilber! Should drop your ET's by at least .5 sec!!
whoa there Steve-o! half a second would would be a quite significant improvement! I never figured on those "drag" pipes actually having any performance improvement whatsoever. But then I always ditched 'em for ground clearance reasons...not an issue on the strip. Curious if you did any street tests after installation or any jetting changes?
Quote from: Stev-o on November 04, 2018, 12:35:12 PMLooks good Wilber! Should drop your ET's by at least .5 sec!!Quote from: seanbarney41 on November 04, 2018, 12:46:30 PMwhoa there Steve-o! half a second would would be a quite significant improvement! I never figured on those "drag" pipes actually having any performance improvement whatsoever. But then I always ditched 'em for ground clearance reasons...not an issue on the strip. Curious if you did any street tests after installation or any jetting changes?LOL! Don't know if there will be any performance gain, simply an indulgence. I'll likely sync the carbs, do some plug chops, and index the plugs next weekend.
I bet it will feel more powerful on the butt dyno!
