Author Topic: I hate my ______ because ...  (Read 2909 times)
Offline babyfood1217
  • The only way to drink espresso is as a
  • I miss my baby...
« on: May 23, 2006, 07:11:45 PM »
Clutch cable - it broke on my way to work today.  Not ten miles from work, I just pulled off the interstate and was luckily right across the road from a gas station, about to make the last stretch through the desolate countryside, when my clutch lever slammed into the handle and the bike lurched and died.  The damn nubbly thing that catches in the slot of the lever ripped right off and dropped to the ground.  Sad me had to wait through a terribly long day, hoping not only that my local bike shop would have the new cable, but also that the bike would still be there when I got back.  So, here's the moral of my story.  Be prepared for anything.
-Chris Gerber
I need help moving my project bike from Wisconsin to Seattle, WA.  Willing to pay well.  Contact if interested.
SOHC member: #438
Project: 1976 CB750K
GSXR forks, Monoshock Rear end, 836 in progress, RC51 pipes, custom frame and everything else.
Offline oldbiker
  • I HATE RAIN
Re: I hate my ______ because ...
« Reply #1 on: May 24, 2006, 12:05:27 AM »
That 'nubby' thing.  You could buy and carry with you a spare  with a fixing screw. It's like a small barrel with a hole through the side for the cable and a small screw in the end to tighten and grip the cable. It is good enough to get you running and home.
Offline mcpuffett
« Reply #2 on: May 24, 2006, 12:12:37 AM »
i carry a old tobbaco tin , it has spare points and condensers, also a variety of solderless nipples , i had to use 1 last year when my clutch cable did the same thing , got me home 30 miles  ;)  mick.
Offline Raul CB750K1
« Reply #3 on: May 24, 2006, 12:24:03 AM »
Did you say "nipples"?
Raul
Offline mcpuffett
« Reply #4 on: May 24, 2006, 12:31:54 AM »
yep nipples :D
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #5 on: May 24, 2006, 01:20:36 AM »
Watch it you lot.  The great moderator's post-sifting programme has detected the word "nipples"  ;D
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
« Reply #6 on: May 24, 2006, 02:32:30 AM »
I often post in a music forum and the language check is so lame that even the word "HELL" is automatically banned.
Raul
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: May 24, 2006, 02:37:59 AM »
I think I envision this, sounds like an interesting little gadget to have along. Can you be more specific about what it's called and where to find one??
Offline scunny
  • don't call me expert
« Reply #8 on: May 24, 2006, 02:39:53 AM »
thru a sad affliction I support S#$%*horpe United. thus the scunny, some mail programs think S#$%*horpe is the gateway to a porn empire....... #$%* are they?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #9 on: May 24, 2006, 07:07:44 AM »
Bob they are actually called, wait for the hellfire and damnation, SOLDERLESS NIPPLES. I used to make up lots of cables at one time and over here they are not allowed on brake cables at anual test so here is a trick. On one side of the hole in the brass nipple that the cable goes through open up the diameter, push the cable through and "mushroom" the  end so it fits the bigger diameter then warm up the assembly and drop some solder in. Instant SOLDERED NIPPLE
Offline oldbiker
  • I HATE RAIN
« Reply #10 on: May 24, 2006, 07:11:47 AM »
Hi Bob,As Brian says they are called solderless nipples. His answer makes a good repair but the idea of these is a "get you home" solution. Please excuse the rough freehand sketch. It is very simple to make if you have a lathe or a friend with access to one.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #11 on: May 24, 2006, 08:00:23 AM »
nipple   ;D
« Reply #12 on: May 24, 2006, 08:04:49 AM »
Tell you what Bryan, no wonder the DOT doesn't approve them. I've never used and I don't trust much on it either. I also rather solder them; less chances of going loose.
Raul
eldar
« Reply #13 on: May 24, 2006, 08:32:09 AM »
You take what you get in order to get home!
Offline DrMark
« Reply #14 on: May 24, 2006, 09:01:16 AM »
I like the idea of having a couple of these in my saddlebag. Where can I buy these in the U.S.? What sizes do I need?
1978 CB550K
1983 CB650SC Nighthawk
Offline mcpuffett
« Reply #15 on: May 24, 2006, 09:33:26 AM »
thats what they are fellas a simple get you home  ;), if you get them good and tight and try not to use the clutch to much they will work ;)  mick.
rt
« Reply #16 on: May 24, 2006, 10:05:59 AM »
DrMark: if not sure why not simply go into an automotive shop and ask '..excuse me, but what size should my nipples be?'  ;D
Offline hcritz
« Reply #17 on: May 24, 2006, 11:49:41 AM »
Hey Guys...
Our Lowe's had "Brass Nipples" ...the "screw" type...in all differnt sizes...think I'll pick up some for emergencies!
Hadn't thought about a clutch cable failure...
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #18 on: May 24, 2006, 03:43:05 PM »
Do they get hard if you blow on them? :o
Fonda Honda
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #19 on: May 24, 2006, 03:49:36 PM »
Thanks, understood the drawing fine and the next set of photos as well. Almost looks like the same principle used for joining elec. wires inside boxes before they came up with wire nuts.
Offline grumburg
« Reply #20 on: May 24, 2006, 03:59:00 PM »
Had one break on a 650 Yamaha as I pulled into my garage at a pretty good clip. Only time a ever used the kill button. Came in real handy!
Fonda Honda
