Author Topic: WD 40 Profit slips  (Read 1047 times)
Markcb750
WD 40 Profit slips
« on: January 10, 2012, 01:22:49 AM »
http://news.yahoo.com/wd-40-profit-drops-25-percent-221542363.html
I pass on WD 40 now, just not worth 8 bucks for a can.
It never made a very good lubricant, as it evaporates away and leaves very little lubricant behind.
I use plain oil from a straw, or a little grease to lubricate something.  A $2.99 a can brake cleaner to clean up a greasy mess.
High end rattle-can paints have gone crazy too.  I use SEM high fill primer which is up to $18 a can.
Offline mcpuffett
Re: WD 40 Profit slips
« Reply #1 on: January 10, 2012, 01:34:10 AM »
Same here in the UK WD40 is expensive and the supermarkets have there own brand for 99p cheers Mick.
« Reply #2 on: January 10, 2012, 02:28:00 AM »
I use Rem-Oil instead of WD40.  It is a real oil and helps to keep the metal rust free.
« Reply #3 on: January 10, 2012, 03:27:57 AM »
http://www.roadsters.com/gibbs/
Anyone tried this stuff, it reads well..?
Offline Raul CB750K1
« Reply #4 on: January 11, 2012, 12:49:14 PM »
WD40 is not a lubricant?
Then, what is it for?
I have been using it as a lubricant for years now....  just recently I discovered it is great for cleaning grease!
« Reply #5 on: January 11, 2012, 12:59:03 PM »
It was originally designed to repel water and prevent corrosion.
WD-40 stands for "Water Displacement – 40th Attempt".
It lubes too but not as much as real lubricants.
« Reply #6 on: January 11, 2012, 03:22:07 PM »
I don't think its a good lubricant at all, it tends to take of other lubricants off, i use it to preserve parts short term or to wash parts down....
Offline 333
  • Time for change
« Reply #7 on: January 11, 2012, 03:56:15 PM »
As already stated, it was never meant to replace other lubricants.  But it is great at loosening frozen or rusted stuff, as well as the water displacement thing.  I find it invaluable in removing adhesive residue.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
