Author Topic: Reliable classic cars for winter  (Read 8247 times)
Offline Prospect
« on: January 10, 2012, 06:42:15 PM »
I know this sounds a bit odd but are there any 35 plus year old cars or trucks that are good for the winter? Cars that have stood the test of time and weather.  I'd like to eventually get a winter beater and much prefer older cars as I know how to work on them.  Problem is they're usually hard to start in the winter and electrics don't like the moisture.  There is a guy down the street that drives an old land rover all winter and I don't think it has heat.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline mickey6
Re: Reliable classic cars for winter
« Reply #1 on: January 10, 2012, 07:32:34 PM »
Well my daily driver is a 53 Plymouth cranbrook. I have never had a cold start issue and all the original electric components work flawlessly and it's still 6 volt ;D. If you get an old car just be ready to take care of it (regular upkeep and fix a problem when it starts showing up) and it'll be fine.
76 cb750F in 7 boxes
73 cb500 daily cafe
« Reply #2 on: January 10, 2012, 07:39:08 PM »
Someone here posted his collection of early 70's era chevy trucks once. They are almost bullet proof, still reasonable to buy, anyone mechanical can work on them. There are millions of used engines that fit. They come in 4wd too. the drawback is fuel mileage. I assume with the correct engine that can be addressed to an extent too.
« Reply #3 on: January 10, 2012, 08:08:20 PM »
Prospect, do they salt the roads there?  If they do, an old car in the winter is gonna be a losing proposition for you.  Even a clean, solid old car will not last long in the salt (2-3 years maybe)...and, to me, it would be a selfish crime to to expose it to a salty, rusty, inevitable destruction.  I live in Michigan, where the roads are salted, and rust free bodies cost 2+ times what they would down south or out west.  I've had several old cars for winter beaters that were already too rusty for it to be practical to make 'em nice.  They all ended up with a rear spring shakel coming through the back seat.  They all ran perfect with awsome tropical blast heaters after 100's of thousands of miles when said rust destruction reared it's ugly head...the list- '75 Plymouth Fury, '73 Olds Omega, '76 Chevy Malibu, '91 9c1 chevy Caprice, '90 Dodge van...currently watching a '95 Chevy g10 van return to the iron ore it was made from...
Offline Kong
« Reply #4 on: January 10, 2012, 10:08:35 PM »
Old VW bugs were pretty good in the winter, if the heater still worked.  Air cooled engine meant no anti-freeze/water-pump problems, they started easily, and rear-engine-rear-wheel-drive meant they got along well in the snow too.  They got pretty good gas milage and were fun to drive in the sense that you could just wail on them and not do much damage.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Emokid
  • Easy you say ? Now where's the fun in that ?
« Reply #5 on: January 10, 2012, 10:17:57 PM »
Second that , my first car was a 57 beetle ( at the time more than twice my age) ran perfectly through the winter , and handlrs well on snow and ice .
Put in a webasto heater if you ever go that route though , the old airboxes are usualy rusted out , clogged or whatever and you might just freeze your b..s off :)
-76 550f ,transforming into the 798 "Nazgul" cafe
http://forums.sohc4.net/index.php?topic=97563.0
Offline LokisTyro
« Reply #6 on: January 10, 2012, 10:34:52 PM »
+ another on the V-dub. However their crash ratings are ridiculous and they make rev-matching dull and tedious IMO.
"Get confident, stupid!" -Phil Hartman as Troy McClure
Offline BeSeeingYou
« Reply #7 on: January 10, 2012, 10:38:14 PM »
reliable 35+ year old car for a northern winter..... ;D ;D ;D ;D ;D ;D
Offline faux fiddy
  • bike in a box
« Reply #8 on: January 11, 2012, 01:38:24 AM »
The old jeep eagle hatchback had reliable running gear and you can still find them. Not sure about all around liability, but the AWD or whatever it was kept you going forward.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline tramp
« Reply #9 on: January 11, 2012, 03:43:58 AM »
old wranglers are pretty good
old dodge diplamat
had a cop car that was great in the snow for a rear whel drive
1974 750k
Offline Prospect
« Reply #10 on: January 11, 2012, 06:41:39 AM »
Thanks for the responses guys.
Looks like there are options but I didn't consider the combination of salt and old metal as Don R mentioned. They excessively salt the roads here and it would probably eat 70's detroit bodies in short order.  Would modern anti-rust proofing stop the rust or is it a waste of time?
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
« Reply #11 on: January 11, 2012, 02:36:18 PM »
yeah, there is good rust proofing such as por-15 etc. now, but it is really impossible to get it to where the rust actually starts, ...inside frame rails, inside quarter panel, box sections of sheetmetal such as rockers, window channels, etc. etc....I think they should use por-15 on the road instead of salt to melt the snow and ice ;D
Offline 72 yellow
« Reply #12 on: January 11, 2012, 04:38:40 PM »
9c1 Caprice....Old bathtub cop car..Worked on many of those.
Offline rbmgf7
  • 2>4
« Reply #13 on: January 11, 2012, 05:59:45 PM »
Classic Bronco, baby!  8)
Ted Nugent's 1974 Ford Bronco
Offline BLUE71TURBO
« Reply #14 on: January 11, 2012, 07:11:38 PM »
  Now this is what you need !   :o  8)
         PRINOTH TROOPER Track Vehicle Sand and Snow
« Reply #15 on: January 11, 2012, 08:07:58 PM »
The beetle is good if you learn to work on them. They are quirky but not hard once you learn what they want. A 12v blower motor on the stock, well maintained heater boxes works well. They go under the back seat, mine was awesome. It would even defrost the windshield.
Offline Prospect
« Reply #16 on: January 12, 2012, 04:58:55 AM »
Are they very prone to rust?  Like I said they salt the roads here all the time.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline mickey6
« Reply #17 on: January 12, 2012, 12:36:51 PM »
anything that old is going to be prone to rust in the road conditions where you are at.
73 cb500 daily cafe
Offline Prospect
« Reply #18 on: January 12, 2012, 04:56:15 PM »
Oh well.  There goes that idea.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
Offline BeSeeingYou
« Reply #19 on: January 12, 2012, 05:09:03 PM »
Like your location the use of chemical/salt deicers here is pretty heavy.  The only decent 35+ year old cars you see here are in the hands of collectors who use them in the summer.  The others are either in the junkyard or the few you do see on the road are in tough shape.  I would imagine the situation is similar where you are at.  I suppose you could find something from the warmer parts of the U.S.  but the better idea is to rethink the whole thing and get something newer.   It's also a safety issue with the airbags and the better impact resistance of the newer cars.  The old beaters are death traps in comparison.
Offline mickey6
« Reply #20 on: January 12, 2012, 05:47:25 PM »
+ one get something 90s or newer with front or all wheel drive.
73 cb500 daily cafe
Offline Gordon
  • 750K1, 550K2
« Reply #21 on: January 12, 2012, 05:58:21 PM »
AWD Subaru!
I've had a '96 Legacy wagon for six years.  It was a great winter weather car when we lived in Denver, and it's actually really easy to work on.  Plus it has all the modern safety features like air bags and anti-lock brakes.  It's sneaking up on 200K now and still going strong, although now that we're in Texas and don't need the AWD, the lure of a mid-size truck is getting much stronger. :)
Offline BeSeeingYou
« Reply #22 on: January 12, 2012, 06:13:31 PM »
+1 on Subaru
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #23 on: January 20, 2012, 02:58:30 PM »
Jeep Waggoneer ! I had a 1967 it was the best car I ever owned. It's still running around an orchard in Eastern Washington. I sold it 30 year ago. They will go anywhere, period.
Subs are ok but I would stick with an older mid 80s GL. I had three of them all had over 200K on them. One had 300K and I sold still running and driving great. Legacys? I've had two (1992 and 1996) and I won't buy another subaru again especially the newer ones.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Grnrngr
« Reply #24 on: January 20, 2012, 04:34:59 PM »
I had a 67 and a 70 wagoneer and a 64 International scout when I lived at Tahoe, I'd be happy with any of them again, but yeah...gas sucks in 4x4 gas vehicles. Subarus were also very popular, and I'd be happy with either m 86 Bronco 2 or 90 Ranger 4x4. Cars? Not so much, although my 70 Bel Air, 72 Satellite, and 74 Grand Prix all did real good in the snow. You're kinda late to do it this year, but if everything near you is a rust bucket, wait til spring/summer, find one somewhere in the flatlands where there's no rust and undercoat the heck out of it, you should get a few seasons out of it..
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
