Hello all, glad to be on the site
yet another new member. Hopefully it's ok to start with a question: -
I bought a 1978 CB550F Super sport today, the centre stand has a piece snapped off it which has rendered it unfortunately rather useless so I intended to remove it and buy a restored stand.
I have taken out the small pin, and I have undone the bolts on each side of the stand, I then tried to tap the large pin around which I assume the stand moves out with a screw driver wrapped in rags and a rubber mallet. So far I have got little to no movement from the pin and I just wondered if anyone can tell me if I am going about this the right way.
I have not removed the spring from the stand as I had read on a similar post that it made it easier to remove the stand, unfortunately they didn't shed much light on how to remove the big pivot pin (if that's the right name for it).
Thanks in advance
