Author Topic: 2 stroke engine problem  (Read 1910 times)
Offline 2wheels
« on: January 21, 2012, 06:36:36 AM »
I have a 500 cc 2 cylinder, liquid cooled, 2 stroke.
It runs fine at idle and midrange, has the expected power there as well.
Anything past half throttle there is just nothing.
The motor still sounds fine power does not change.  No coughing and sputtering.  Just no increase in power.
Any ideas?
Carbs have been cleaned several times, but I'm not saying I did it right.
Ignition is CDI
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline CycleRanger
  • No comment about being an
Re: 2 stroke engine problem
« Reply #1 on: January 21, 2012, 06:49:19 AM »
Oh oh I'll guess it's a....Rotax?   A... Suzuki?  A... Bimota???
Offline 2wheels
« Reply #2 on: January 21, 2012, 07:04:50 AM »
Rotax
In a a 20 year old Ski Doo
Offline CycleRanger
« Reply #3 on: January 21, 2012, 07:25:54 AM »
Hah! First guess! :)
Are you sure the throttle cable is adjusted correctly? Sounds like the carbs might not be opening all the way.
Offline 2wheels
« Reply #4 on: January 21, 2012, 07:59:36 AM »
It sure feels like they are not opening up.  But I checked and they are.
I was thinking the main jets are sized wrong (they may be) but I think with the throttle wide open the mixture would be so far off the engine would run really bad.
But that is not happening.
I should add this is a franken-machine / barn find.  So anything is possible.
Probably not a good choice for my first 2 stroke repair experience.
But hey,  it was free and we are having fun.
Offline CycleRanger
« Reply #5 on: January 21, 2012, 08:04:44 AM »
It doesn't have some kind of governor on it does it?
Free? That's the best price!
Offline 2wheels
« Reply #6 on: January 21, 2012, 08:26:56 AM »
89 ski doo Clutch
here is a video of the clutch operation,  we were thinking this may have been the problem but now I am not sure.
Anyway with the back end of the machine tied in the air we could open it right up.
It does say something that it will open up when there is no load on it.
There is no speedometer so I'm not sure what a governor would look like.
Offline CycleRanger
« Reply #7 on: January 21, 2012, 09:06:20 AM »
89 ski doo Clutch
Well, I know nothing about these engines but there may be an electronic module that limits RPM.
Just guessing.
I'd go googling for a shop manual. If it's that old there's bound to be one online somewhere.
    • http://forums.sohc4.net/index.php?PHPSESSID=ig37ltueq6ra90ttjv2bkmbfr7&/topic,60973.0.html
« Reply #8 on: January 21, 2012, 09:17:53 AM »
mine yamaha dt..have same problem,, it vas the ignision coil extern..took one from a china dirt bike..and it runs super fine
Offline 2wheels
« Reply #9 on: January 21, 2012, 09:20:42 AM »
I never thought of a governor before you mentioned it.
It is a good possibility so I wil check into that.
Offline 2wheels
« Reply #10 on: January 21, 2012, 09:27:16 AM »
strynboen
I was hoping it is not ignition.  All these parts are so expensive.
But as you discovered it can be.
I may need some spare parts I can swap to find this problem.
Offline mrrch
« Reply #11 on: January 27, 2012, 06:27:55 PM »
If it was actually stored in a barn check the exhaust for blockage (mouse nest/ happens alot with snowmobiles )
my build
Offline faux fiddy
  • bike in a box
« Reply #12 on: January 28, 2012, 02:01:08 AM »
+1
Mud daubers  and wrens can work in the holes , too.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline 2wheels
« Reply #13 on: January 30, 2012, 03:31:47 PM »
Thanks
The expansion chamber is off right now.  I will put some large nuts and bolts in and rattle them around.
« Reply #14 on: January 31, 2012, 02:18:14 AM »
Rotax
Put it in a bike...... ;D ;D
