Author Topic: Its time to build a 836 Turbo  (Read 106134 times)
Offline Bill/BentON Racing
    • BentON Racing
Re: Its time to build a 836 Turbo
« Reply #175 on: March 17, 2012, 01:19:05 PM »
I can't! Lost my cell phone @ Smallmart earlier!Bummer >:(
PM me your cell.Thanks,Bill
I did e mail you.
BentON Racing Website
BentON Racing Facebook
Offline Jim F
  • go baby go
« Reply #176 on: March 25, 2012, 01:18:02 PM »
Just a quick update
Still waiting on the cam, cylinder studs, and a few other parts that are still on order to come in
Mike is cracking the whip on his end and doing a fine job in support of this project.
the crank is still out and I hope to hear something be the end of the week
next is the plain bearings and the big end bearings,
case studs need to be installed but I am waiting for the crank and bearing work to be finished before that
more to follow as soon as I get the crank in
Jim
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline bikebitzofvt
« Reply #177 on: March 25, 2012, 03:22:34 PM »
Just read thru the build so far and it looks awesome!
Do you have a build thread for your avatar bike?  Love the look but it's a rather small pic...
Keep up the great work!
Tom
"If it ain't broke you aren't riding it hard enough!"
77 CB750K7, 77 KZ1000B
Offline Jim F
  • go baby go
« Reply #178 on: March 26, 2012, 05:38:40 AM »
This is the bike that's my avatar
It's also the subject of the turbo build
« Last Edit: March 26, 2012, 09:48:13 AM by Jim F »
Offline ThomasD883
« Reply #179 on: March 26, 2012, 03:39:26 PM »
That fairing looks massive!  You need a turbo to push that through the air! :D
« Last Edit: March 26, 2012, 04:11:33 PM by ThomasD883 »
Diesel deeds, done dirt cheap
Offline Jim F
  • go baby go
« Reply #180 on: March 26, 2012, 09:09:53 PM »
I have actually done a lot of trimming to get the look the way  want it
but it is a large fairing but it does a good job of getting a large guy out of the wind
I had the bike around 100 or so down one of my highways and the bike was rock solid
I am thinking of changing the seat to give me a larger seat area (But still a cafe style seat) to rest my big rear end on as that CR replica
is damn uncomfortable
Jim
Offline Jim F
  • go baby go
« Reply #181 on: March 31, 2012, 06:50:17 AM »
Got the clutch cover machined for the drain line
that was kind of scary as there is not a lot of room
from braking into something that your not suppose to
and braking out on the sealing surface
but it worked and should be find
still waiting on the crank..................dang
« Reply #182 on: March 31, 2012, 07:25:24 AM »
.....cylinder studs. ;) I think I'll send you a clutch cover for the same work Jim...I need it for a -8 breather hose.
Offline Jim F
  • go baby go
« Reply #183 on: March 31, 2012, 08:10:31 AM »
Send it down mike
Well take care of it
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« Reply #184 on: April 02, 2012, 12:07:41 PM »
Do you need that large of a drain line?
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline BLUE71TURBO
« Reply #185 on: April 02, 2012, 03:17:43 PM »
                Oh yes you do.  The larger you can go the better.  For a oil drain off of a turbocharger the line must be large because of the turbo spinning so super fast causes the hot oil that is draining to become " FROTHY" or " FOAMY ".  You always want the oil line to drop down as low as you can below the turbo"s housing for better drainage.   ;)
Offline Jim F
  • go baby go
« Reply #186 on: April 02, 2012, 05:48:28 PM »
I looked at putting it next to the kick starter but there are some strengthening ribs in that area
and I didn't want to have to mill those away to get it to drain.
I just moved between the next set of clearance holes and it should be fine
Terry kizer (Mr. Turbo) replaced all the hoses with new ones and he said that the return needed to be as big
as possible just as Jon mentioned
Offline Jim F
  • go baby go
« Reply #187 on: April 19, 2012, 11:54:27 AM »
When Brian called and said there was a work of art sitting in his shop.
I really didn't be leave him
the pictures don't do this crank and rods any justice at all
enjoy what a lightened, balanced and nitride coated crank looks like (You really have to see it in person)
and of course the carillo rods
  • Moderator
« Reply #188 on: April 19, 2012, 12:26:22 PM »
 8)
« Reply #189 on: April 19, 2012, 12:30:43 PM »
 8) +1     Sweet
  • Moderator
« Reply #190 on: April 19, 2012, 12:32:23 PM »
SWEET :o :o :o  ??? ??? ??? ???
Sam.  :-* ::)
    • BentON Racing
« Reply #191 on: April 19, 2012, 04:29:32 PM »
Hey Jim,can I borrow that also? ::) ;D ;D ;D ;D ;D ;D Bill
Offline Big Jay
    • CBRzone
« Reply #192 on: April 19, 2012, 10:11:38 PM »
That crank has been lightened?
Offline Jim F
  • go baby go
« Reply #193 on: April 20, 2012, 05:17:57 AM »
only on the out side of each big end assembly. They machined off about .250 per half of the counter weights (???)
and left the in side alone (Between the con rods)
I was more concerned about getting the balancing part perfect
and keeping it plenty strong
This is the same application that Brian at livingood motor sports use when he builds his road race motors
and has never had a crank fail
Also the nitride coating  makes the crank look dull so its not quite as pretty as your cranks
Jim
« Last Edit: April 20, 2012, 05:25:10 AM by Jim F »
Offline romerider153
« Reply #194 on: April 20, 2012, 06:37:39 AM »
i was curious what size fitting that is for the clutch cover is that -8 to 3/8 npt?
Offline Jim F
  • go baby go
« Reply #195 on: April 20, 2012, 11:56:35 AM »
thats a 3/8 NPT supplied by Mr. Turbo to fit the oil drain line out of the turbo
it needs to be as big as you can get it
Jim
« Reply #196 on: April 20, 2012, 01:01:45 PM »
is the an side of it -10 or -8 pictures appear to be 10 but cant tell for sure
Offline Jim F
  • go baby go
« Reply #197 on: April 20, 2012, 06:44:56 PM »
Not sure I understand what the numbers represent.
sorry
Jim
« Reply #198 on: April 20, 2012, 07:16:39 PM »
sorry
Jim
Jim....is the AN tapered side a -10 or -8......it looks big in the pic like a -10.
Offline Jim F
  • go baby go
« Reply #199 on: April 27, 2012, 05:08:16 AM »
Mike How can you tell?
