Support the site. Your contributions keep this site running.
Hey guysAre there any good oil temp gauges on the market that I can tie into the oil drain plug?or where the oil pressure gauge goesBill uses a system from Daytona products but I don't like the digital gaugemore of an old school kind of guythanksJim
Hey guys....good oil temp gauges on the market that I can tie into the oil drain plug?or where the oil pressure gauge goesthanksJim
Couple of questions I have for you. Where is the turbo oil supply pulled from? Also the intake manifold has two hoses on it. I assume one is for the boost gauge, what is the other for?Looks awesome. Cant wait to hear it.[/quoteOne of the hoses goes to the boost gauge and the other goes to the waste gateThe oil pulled in from the main oil galley behind the cylinder where the oil sensor goesits a special manifold that has 2 openingsgoes in to the turbo and then gets dumped into the clutch cover where the other line is I cant wait to here it alsogetting close but the wiring harness needs to be made and then the ignition programedJim
Quote from: Jim F on September 06, 2012, 07:41:36 AMHey guysAre there any good oil temp gauges on the market that I can tie into the oil drain plug?or where the oil pressure gauge goesBill uses a system from Daytona products but I don't like the digital gaugemore of an old school kind of guythanksJim Hey.....get with it and step into the 90's Jim.
Quote from: Jim F on September 06, 2012, 07:41:36 AMHey guys....good oil temp gauges on the market that I can tie into the oil drain plug?or where the oil pressure gauge goesthanksJimA 'Google' for 'oil temperature gauge' will give you lots of choices. You could also tie it into the fitting for the turbo oil supply.
I plan on being there and participating!!!!!!!!!!!!!!!!!!!!!! Bill
