Author Topic: I goofed!  (Read 1269 times)
Offline katmol
I goofed!
« on: January 26, 2012, 01:08:16 PM »
I was cleaning up a very dirty 750A and the cleaner I used on the wheels turned the clearcoat milky. Anyway to fix that with out stripping the clearcoat off?
'74 CB750K Tracy Project
'76 "Modified" GL1000
'77 CB750A Blue
'77 CB750A Red
'79 CM400A Hondamatic
'81 CM400A Hondamatic
"Gone but not forgoten."
'76 CB750A Muscat Green
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
'78 750K Black Dresser
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: I goofed!
« Reply #1 on: January 26, 2012, 01:15:02 PM »
Usually once that kind of damage is done it is permanent until you completely strip it and refinish it.
You have to be careful sometimes with the cleaning methods used on certain parts.
Ringo
Re: I goofed!
« Reply #2 on: January 26, 2012, 01:19:34 PM »
Kong or another paint guru will weigh in eventually with definitive info, but I would try some buffing compound in the mean time.  Maybe all you need is to rub off the outer layer of clear...
Offline katmol
Re: I goofed!
« Reply #3 on: January 27, 2012, 10:53:59 AM »
OK... now what's the best striper to use on these wheels? Also, should I remove the tires?
'77 CB750A Blue
'77 CB750A Red
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
Offline LokisTyro
Re: I goofed!
« Reply #4 on: January 30, 2012, 09:58:11 AM »
Was it Bar Keeper's Friend that you used? It's a really great cleaner for all sorts of stuff but is hell on clears and paint cause of the abrasives in it.
"Get confident, stupid!" -Phil Hartman as Troy McClure
Offline katmol
Re: I goofed!
« Reply #5 on: January 30, 2012, 03:06:44 PM »
No, it was an aluminum cleaner and I didn't rinse it good enough.
'77 CB750A Blue
'77 CB750A Red
'70 CL450 Scrambler
'72 CL350 Scrambler
'75 CB750K Stock
Re: I goofed!
« Reply #6 on: January 30, 2012, 05:27:06 PM »
I'm wondering if you dulled the aluminum rather than a clear coat. There could be a lot of polishing in your future.
