Author Topic: honda cb400f help me make it run right  (Read 10138 times)
Offline aydynla
Re: honda cb400f help me make it run right
« Reply #25 on: January 27, 2012, 09:05:06 PM »
This is a pic
Offline Ernest T
« Reply #26 on: January 28, 2012, 09:02:57 AM »
That's corrrect, you can't put them in backwards because the slides have a goove in them and a small tab which have to line up. Those slides are real high though.
Offline aydynla
« Reply #27 on: January 28, 2012, 09:32:30 AM »
They are not bight, they are installed backwards. They can not be turned around, they belong to different cylinders. Ill have to disassemble and move them around.
I hope that will fix my three week battle.
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
« Reply #28 on: January 28, 2012, 09:47:50 AM »
Hopefully that will do the trick.  Switching them out is a little laborious, but it will be worth it!
Offline Ernest T
« Reply #29 on: January 28, 2012, 09:53:09 AM »
Maybe I don't understand the picture, is that the top of the cut out?  The edge looks pretty flat so I thought the slides were just way high in the carb.  I never considered the parts could have been swapped between carbs 1-2 and 3-4.
Offline aydynla
« Reply #30 on: January 28, 2012, 10:04:10 AM »
I guess they could. I will  know by Monday. Somehow it was done. No air passing at idle.
Offline aydynla
« Reply #31 on: January 28, 2012, 10:08:33 AM »
What would be the best bowl gasket to buy? The one that doesn't swell?
Ill have to return floats to 22mm and this gaskets will trash once I open it again
Offline Ernest T
« Reply #32 on: January 28, 2012, 11:48:00 AM »
Can't go wrong with Honda OEM parts.
Offline hondamatteo
« Reply #33 on: January 28, 2012, 03:38:19 PM »
http://www.siriusconinc.com/pro-detail.php?pid=&product_id=1506
These ones are nice cause they are pre shaped unlike the generic round ones that you have to shape and always fall out of place and get pinched, then leak. They can work and there are tricks to getting them to stay in place but if you are always tinkering like me its not worth the time or effort.
'74 CB350F
Offline aydynla
« Reply #34 on: January 28, 2012, 08:54:20 PM »
Thanks,ill try them. Ill know by Monday if bike runs or not. This may continue
« Reply #35 on: January 28, 2012, 09:36:27 PM »
+1  ;),they last a very long time indeed...and with the crummy ethanol type fuel available that seems to break down carb rubber parts quickly..I'd go for a few sets of factory Honda carb rubber kits;they have all the rubber parts for each complete carb in one kit.
Offline Ernest T
« Reply #36 on: January 29, 2012, 06:42:07 AM »
A little vaseline holds the round ones in place while you install the bowl, then it just dissolves in the gas, but the shaped ones are really nice.
Offline Psychonaut
« Reply #37 on: January 29, 2012, 11:38:37 AM »
Mine swell too but if i let them sit and dry out they shrink back to where they will fit again.
I thought the book says 21mm on the float, I could be wrong.
Offline aydynla
« Reply #38 on: January 29, 2012, 04:21:07 PM »
Just an update. Switched those slides and bike runs great so far. No smog, no issues. I didn't even synch them yet. Thanks for everyone's help and involvement
I was about to buy another set of carbs. I can continue with.my project now knowing bike runs well.  I have three motorcycles ducati sports classic Bonneville and now cb400f and I always had best of luck on forums. Thanks again for taking your time to respond and and help fellow rider in need.
Bike runs well without airbox and synch I can only imagine how it will run once I throw those on
I have noticed gaskets returning to shape after a few days. I guess I should keep couple sets at home. And for those who rejuvinate rubber boots using xylene and wintergreen oil: I tried same thing with olive oil and a week later they are still h
Good. Wintergreen hard to find in Los Angeles county and so is xylene, its not allowed to sell any longer here.
« Last Edit: January 29, 2012, 04:38:27 PM by aydynla »
« Reply #39 on: January 29, 2012, 05:25:25 PM »
Offline Ernest T
« Reply #40 on: January 30, 2012, 05:28:21 PM »
Terrific, its a wonder how nice they run with things in the right way!
Offline magconpres
« Reply #41 on: February 08, 2012, 10:34:00 PM »
It's a wonder they run at all with things in the wrong way!
1975 CB400F, stock,  on the road
1975 CB400F, ran when I parked it. Cafe Racer bound
1986 TLR200 commuter and trail bike when with the kids...90MPG!
1986 TLR200, Vintage Trials build up coming
1986 TLR200, Not sure what to do with this one...Vintage Trials Super Moto?
2004 GasGas 300EC...my enduro racer
2004 Sherco 290...Trials bike
2004 CRF70... Son's ride
2006 PW50 ... Daughter's ride
1982 XL500R (04 XR250 front end)...my DS bike.
