Author Topic: Engine side fittings for A/N hoses?  (Read 1834 times)
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« on: January 28, 2012, 04:46:50 AM »
I tried the search, but the few threads dealing with oil hoses did not answer my question. When plumbing a cooler with braided steel A/N lines, ala CR750, what solution is there for the fittings on the engine? Mill the end of the Honda fittings for A/N fittings? Or does someone know a better way?
Thanks,
Gonzo
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Re: Engine side fittings for A/N hoses?
« Reply #1 on: January 28, 2012, 07:38:21 PM »
We used to weld AN fittings on to the stock fitting with the rubber part and ferrule cut off.
 I bet on the lathe I could build a fixture to actually thread them and cut the tapered seat on them.
Offline Gonzowerke
« Reply #2 on: January 28, 2012, 08:08:41 PM »
I kinda figured it would be something like that...
Thanks for the reply though!
Offline Doctor_D
« Reply #3 on: January 29, 2012, 06:53:55 AM »
Tap the cases with 3/8 NPT tap, then use the Russell 90 deg, npt to -8 AN swivel fittings.  http://www.jegs.com/i/Russell/799/612100/10002/-1  It can be done with the motor in the frame, thought you'll want to drop the sump and oil pump to make sure you're not leaving metal in the engine.
« Last Edit: January 29, 2012, 06:55:58 AM by Doctor_D »
Take care,
David
1978 CX500
1971 Norton Commando
Offline Gonzowerke
« Reply #4 on: January 29, 2012, 08:24:52 AM »
You know, I was wondering about that, I just hadn't gotten around to taking measurements with my verniers. Another thought I had was using tube adaptors on the Honda barb ends, but have yet to take apart a stock hose to see what the barb end looks like. I will definitely go the tapping route though.
Thanks!
« Reply #5 on: January 29, 2012, 08:47:11 AM »
I would rather not tap the cases, unless they were already damaged and fixed , Ie chain hole..
 just thinking what if youy wanted to go back to stock one day..
Offline Doctor_D
« Reply #6 on: January 29, 2012, 04:22:50 PM »
It'll still accept an O-ring and a stock fitting.  It doesn't really cut threads until you get in there a bit, where the orifice decreases in diameter.
Take care,
David
1978 CX500
Offline Gonzowerke
« Reply #7 on: January 30, 2012, 11:13:15 PM »
754,
If you look at Dr.D's pic, you will see that the o-ring seats are not touched at all. I do believe this is the route I shall go!
