Author Topic: Making an led tail light(any electronics experts?)  (Read 1979 times)
Offline 68grandprix
« on: May 26, 2006, 12:04:12 PM »
I bought a circuit board and some red LEDs the other day because I wanted to make a really thin tail light to french into the rear edge of my solo seat. I soldered the LEDs in series into the board and tested it, but they are very dim. I tested a single one and it was the same brightness. Does anyone know the correct type of LED to use for a tailight? I had an LED tailight that I bought(it was like a trailer marker light) and that thing was really bright. The LEDs I got are 12volt, and the brightness is 1.5mcd(whatever that is, it's not very bright). Thanks, Jimmy
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Making an led tail light(any electronics experts?)
« Reply #1 on: May 26, 2006, 12:18:08 PM »
There has been some discussion here about LED taillamps.  Modern bikes have them so why can't we make them work?
First question:  LEDs require current limiting, normally by a resistor.  You say they are "12V". If you buy an LED from Radioshack (or similar) and connect it across a 12V source with no resistor, it will shine very brightly (but not for long...)  So do these LEDs come with current limiting resistor?
Next:  If you connect them in series you are "sharing" the voltage between them and they will be dim. The more "sharing", the dimmer they will be.  If they have built-in current limiting, they should be connected in parallel.
cd = candela which is a measurement of brightness. One candela is defined as the luminous intensity in a given direction of a source that emits monochromatic radiation of frequency 540 × 10-12 Hz and whose radiant energy in that direction is 1/683 watt per steradian (that's told you!)
mcd = micro candela or Mega candela depending upon whether the "m" is lower or upper case.
I'll stop now before I enter the "he doesn't know what he's talking about" region...
« Last Edit: May 26, 2006, 12:58:39 PM by SteveD CB500F »
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #2 on: May 26, 2006, 12:43:37 PM »
First question:  LEDs require current limiting, normally by a resister.  You say they are "12V". If you buy an LED from Radioshack (or similar) and connect it across a 12V source with no resister, it will shine very brightly (but not for long...)  So do these LEDs come with current limiting resister?
You entered the "I don't know what he's talking about region" when you typed Resistor!
Offline Hondell
  • Just an easy 1000 Hr. resto
« Reply #3 on: May 26, 2006, 01:05:02 PM »
Hi
Well actually there are 12v leds. They have a resistor built right into the substrate. If in fact you have 12v leds you can safely hook them up in parallel right up to your battery. What you are looking for though is a led with several THOUSAND millicandela.
Rick
1972 Cb750 resto- 1972 Cb750 stoplight racer- 1972 Cb750 vintage touring - 1979 CBX- 1982 Kaw GPZ- 1968 Honda SS125A
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
ponch9
« Reply #5 on: May 26, 2006, 02:22:18 PM »
i'd be glad to help. i am an electrical engineer....see this post
you really nee to figure out what you want first. ultra-brite led's like 8000-15000 work great....
http://www.ledshoppe.com/Product/led/LE1002.htm
the brighter the better....you can always use resistance to dim them.
the formula to figure out resistors needed go as follows:
(Vs-Vl)/I=R
voltage supply - voltage allowed (voltage min/max for the LED) divided by the mA for the led.
EX. 12v-3.2/.02=440 Ohms
*note the .02 is mA into amps first
for multiple led's (series only, parallel is not good as is using one resistor for multiple led's) you then add the voltages allowed for the LED's (which cannot be more than the Vs) then that becomes your Vl.
EX. 12v-3.2+3.2/.02=280 Ohms
any questions??? lol
http://www.sohc4.us/forums/index.php?topic=10141.0
scout18
« Reply #6 on: May 26, 2006, 05:34:03 PM »
Ponch how about a parts list and a how to for the rest of us. I can solder but I need a list of stuff to get to put a cool light together like th one you made for the original housing.
Offline 68grandprix
« Reply #7 on: May 27, 2006, 01:50:57 AM »
Today I went to Iowa Radio Supply, and the guy there was very knowledgeable. I bought some bright leds (only $2.55 for $10, radioshack ripped me off at $1.60 something a piece!) and two 120 ohm resistors. I soldered 12 LEDs in parallel and ran the resistors in parallel so when I hit the brakes with the run light on it halves the resistance. They are pretty bright, but the difference between running and braking isn't enough, so I will either mess with different resistors or order some superbrights for the brake light and use this one for running. Pics aren't great, but here they are, Jimmy.
Offline socalenduro
« Reply #8 on: May 04, 2010, 01:13:31 PM »
I just ordered an LED  tail light, but i didnt ask if i needed a resistor or anything...
is there a way to tell with a volt meter?
Offline 333
  • Time for change
« Reply #9 on: May 04, 2010, 07:50:25 PM »
If it is a 12 volt tail light, no resistor is needed.  And a volt meter will only tell you what you have on the vehicle, not what the LED needs.
And don't pull up a 3 year old thread for a fresh question.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline socalenduro
« Reply #10 on: May 04, 2010, 09:08:16 PM »
yes SIR
Offline MJL
  • Don't listen to me, I'm no
« Reply #11 on: May 04, 2010, 09:54:19 PM »
I'm reading your post and looking at your avatar,  :D
Offline bradweingartner
  • 74 CB 550 x2
« Reply #12 on: May 04, 2010, 09:57:29 PM »
Why not? Is consolidation of related and relevant information really a bad thing?
