Author Topic: Substitute Air Filter in 350f  (Read 1295 times)
Offline Haji
« on: January 31, 2012, 06:09:06 PM »
Has any body just cut up an auto air filter and put in the air filter container?  I have seen folks that have put a cone filter on the back of the air box but figured this would work as well as long as you get a similar flow.
Offline Danno
Re: Substitute Air Filter in 350f
« Reply #1 on: February 01, 2012, 02:25:54 AM »
you could do that if it does not cause turbulance to the air stream there are lots to chose from
Offline fmctm1sw
« Reply #2 on: February 01, 2012, 05:26:17 AM »
I cut up a K&N filter from a 550.  There's a thread here somewhere about it...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline HondanutRider
« Reply #3 on: February 01, 2012, 05:43:35 AM »
I have done precisely that on my CB350F!  It worked out fine and doesn't even look that bad...but then, who will ever see it but me when I open the can?
I found a circular auto filter that had the same depth as the CB350F filter cartridge, and then cut a section (removing the wire screen mesh) and mounted it using auto goop glue (which is similar to silicone but stickier and more resistant to gas fumes I believe).  Works fine and probably gives about the same filtering capability as an original.  You can however find and buy new original filter elements for this bike, but they cost more.
