Author Topic: Uhmmm wires...wtf..how do I get this out!!!  (Read 4042 times)
Offline messeduptriple
« on: February 04, 2012, 12:20:42 AM »
K so I wanted to re guide the wires out of the clubman bars. The guy that I bought it from had the clubmans drilled in the middle of the bar unit ....fed wires somehow through to the end of the clutch and brake and fed back out. I now have disconnected all wires from headlamp and now am stuck. Like wtf. They won't budge for anything. I don't wanna cut through cause I might splice wires. Can someone help me here. I'm kinda nervous now...what do I do? Can I just say f it and look for the wiring harness to the two???? If so what are they called? This is nuts...it won't budge either way.
Sent from my PC36100 using Tapatalk
Re: Uhmmm wires...wtf..how do I get this out!!!
« Reply #1 on: February 04, 2012, 12:25:54 AM »
I'm really pissed off right now...I'm going back in the house . Like why is this so fukn hard. I think I'm gonna just say #$%* it and look for the replacement wiring harness...there's no way its coming out. Anyone have a set?? I'm so pissed off
« Reply #2 on: February 04, 2012, 12:35:38 AM »
Offline Danno
« Reply #3 on: February 04, 2012, 12:45:20 AM »
hey bud when I try to get wires out of bars I use either dish soap or gun oil I recommend the dish soap it is a nasty mess to get the oil off them if you are going to reuse them however tight bends sometimes make it so you have to use the oil steady pulling and sometimes pushing with a stick from the other end at the same time and they should come out  I change all the handlebars on my GL's to something lower and not pushed in so I have been through this a bunch of times
« Reply #4 on: February 04, 2012, 12:48:31 AM »
Won't the soap n water mess up the wires if wet???
« Reply #5 on: February 04, 2012, 12:55:27 AM »
Electricians use soap all the time. it will dry out but may get gummy. Keep after it. A wire pulling helps them go back in.
« Reply #6 on: February 04, 2012, 07:24:38 AM »
So just dawn dish soap ??? No water right ?
« Reply #7 on: February 04, 2012, 07:28:14 AM »
A little water also to make it even more slippery. Seems like they should come out easier than they went in from experience.
Offline CycleRanger
  • No comment about being an
« Reply #8 on: February 04, 2012, 07:35:33 AM »
You might try wire pulling gel. Something like Clear Glide.
They sell it at Home Depot although you'd probably have to buy way more than you'll ever need.
Offline Ernest T
« Reply #9 on: February 04, 2012, 07:36:38 AM »
Coming out always seem easier than putting them in, especially on old bars with rust inside.  It's hard to check with the wires in already, but I had a hell of a time putting a set of wires through a set of bars and it turned out there was an obstruction in the bars I couldn't see.  Does it feel like the wires are hung up on something or just tight.  Also, you can clamp the bars in a vice and use something to get some leverage.  You can pull a lot harder than you think.
« Reply #10 on: February 04, 2012, 07:41:21 AM »
So just tip the bars down and pour it in right?
« Reply #11 on: February 04, 2012, 08:31:18 AM »
I tried the soap.... It moved about half way down and now it won't budge...I think that electrical tape budged up inside there. Wtf. The otherside isn't budging
« Reply #12 on: February 04, 2012, 08:35:14 AM »
yeah dude...definately can be one of the biggest pita's in this business...whatever you do, DON'T USE HEAT, or rather, too much...ask me how I know
Offline Bodi
« Reply #13 on: February 04, 2012, 08:39:38 AM »
pouring really hot water in the bars and on whatever wires you can get at will soften the plastic and make it more flexible. You will have trouble at the bend. You should have a pull string on the end coming through so you can get it back for another try if it gets really stuck. soap is a good lube and washes off a lot easier than oil.
Offline mrrch
« Reply #14 on: February 04, 2012, 09:12:20 AM »
I can't tell from the picture but the hole the PO cut looks big, hopefully it does not compromise bar strength.
my build
« Reply #15 on: February 04, 2012, 09:23:47 AM »
 Keep them warm, I mean 100F is way better than 60F.......
« Reply #16 on: February 04, 2012, 10:12:44 AM »
Ok...well this one I'm gonna have to throw in the towel and bring to my local vintage Honda shop. He told me how to but he said he can do it..he's done it a lotta times. I just don't wanna #$%* anything up and this is just to much patience I don't have. Sux I let the wires win but I just had enough.
Offline Kong
« Reply #17 on: February 04, 2012, 10:23:23 AM »
Pull all the wires back out.  Then string them out straight and make sure they are laying all parallell to each other.  Get as much tape off of them as you can first and then only hold the bundle together with two or three wraps of tape spaced every six or eight inches.  Then squirt some liquid dish washing soap on the wires, and attach your pull wire with electrical tape but use as little as possible, substituting a hook bent into the wire for additional tape.  Now, get someone to hold the bars for your or put them in a vice and start pulling.  Pull hard and do not quit until the wires emerge from the center hole and if you can't pull hard enough put a come-along on the pull-wire.  And while you're doing all of this keep one thing in mind all the time; if you take it to the dealer to pull the wires for you because you couldn't virtually all your friends and your old lady will think you're a wimp.  This will cause your friends to abandon you and perfect strangers to laugh at you in parking lots; needless to say your old lady will leave you and hook up with a Republican, a hard-headed breed well known for their own sets of loose wires.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Re: Re: Uhmmm wires...wtf..how do I get this out!!!
« Reply #18 on: February 04, 2012, 10:37:33 AM »
lol... Thanks. I wish I would have known to take the tape off before. I think its few inches inside the bars... Do I need to buy some sorta extended needle pliers??? This is probably the most unfun part of my project so far.
« Reply #19 on: February 04, 2012, 10:59:29 AM »
I guess I'm just confused...I thought I shouldn't get wires wet?? I just thought hot water on wires isn't a good thing?
DH
« Reply #20 on: February 04, 2012, 12:35:26 PM »
If you arent gonna re use the bars, just cut them up in s
several places carefully and remove sections of bar...
just a thought..
Offline LesterPiglet
  • 1977 CB550F2
« Reply #21 on: February 04, 2012, 01:06:16 PM »
No harm in getting the wires wet as long as they are dry before next use.
« Reply #22 on: February 04, 2012, 01:47:13 PM »
just a thought..
[/quoti know I was gonna try that..but was afraid I might cut the wire.
« Reply #23 on: February 04, 2012, 11:34:47 PM »
Guess after Kong told me to step up and do it I said I had to. Got a grinder and cut the #$%*es up. Now I won't be laughed at and my gf will stay with me! Thanks Kong!
« Reply #24 on: February 05, 2012, 12:01:16 AM »
Question now... What are these dark blue wires for??
