Author Topic: Kick starter gear removal  (Read 2047 times)
Offline NickO
« on: February 07, 2012, 04:24:15 AM »
I want to remove all the kick starter gear on our HiPo engine.
After stipping the donor motor, this looks very straightforward? Is it really as easy as it looks, (i.e. remove the kick-start shaft complete with all the gear/springs, etc. and close the hole in the clutch cover)?
Re: Kick starter gear removal
« Reply #1 on: February 07, 2012, 04:27:15 AM »
That gear drives the oil pump Nick
Offline NickO
« Reply #2 on: February 07, 2012, 04:29:54 AM »
Thanks Mike, that would have been an expensive modification!
Did you get my second PM re. barrels?
Offline lordmoonpie
    • Moonpie
« Reply #3 on: February 07, 2012, 04:49:36 AM »
As Mike says, leave the gear to drive the oil pump but you can remove everything else, cut the shaft short and plug the cases.
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline dragracer
  • CB750F Dragbike
« Reply #4 on: December 28, 2018, 10:41:11 PM »
Wish I had read this a month ago.
Online simon#42
  • liverpool
« Reply #5 on: December 29, 2018, 04:41:50 AM »
ah  that is why you had no oil pressure then !  hope you didnt try and start it .
Online simon#42
  • liverpool
« Reply #6 on: January 03, 2019, 10:40:08 AM »
that will be a yes then .
Offline dragracer
  • CB750F Dragbike
« Reply #7 on: January 03, 2019, 12:54:19 PM »
Offline dragracer
  • CB750F Dragbike
« Reply #8 on: January 03, 2019, 12:56:10 PM »
Back on the frame. Will prelube tonight and see what happens 😊
