Author Topic: Pics of CB500 remote ign switch mount???  (Read 2591 times)
Offline puppytrax
« on: May 28, 2006, 07:32:34 AM »
Back when they were new, you could buy a remote mount for the CB500/550 that moved the ign switch up to the handlebar/top bridge. I had one on my CB500 and it worked great. Stock harness was stretched slightly, but there was enough slack to pull it up OK.
...But due to advancing CRS, I don't recall what it looked like or which two bolts it used to mount the switch...
Anybody got a pic???
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
Re: Pics of CB500 remote ign switch mount???
« Reply #1 on: May 28, 2006, 09:18:26 AM »
Check out my gallery for a pic of how I moved my ign. switch and starter button.
Offline puppytrax
« Reply #2 on: May 28, 2006, 09:28:31 AM »
Ah...a tab welded to the frame by the side cover...rather good...  :)
Nice chain by the way...  ::)
What tank is that slim one??? Rather nice looking...Here now!!! What are all these birds doing on a motorcycle site!?!?   ;D
« Reply #3 on: May 28, 2006, 09:59:45 AM »
Mounts on two of the bolts holding the idiot light cluster
Offline puppytrax
« Reply #4 on: May 28, 2006, 10:01:15 AM »
Yes...but two side bolts, or two bottom bolts???
meanboyjr
« Reply #5 on: May 28, 2006, 02:52:55 PM »
Go here...
http://www.crc2onlinecatalog.com/chopper2.htm
and halfway down the page you will find their ignition switch mounting plate.
It looks like it bolts to the top two bolts on the idiot light cluster, which would mount your switch on top, between the clocks.
Or, lacking that, you could fab one up yourself with a jigsaw and a drill.  8)
Offline puppytrax
« Reply #6 on: May 28, 2006, 03:12:49 PM »
Go here...
Thanks for the link! Although that's not the one I recall...the one sold back in the '70's was like a big number "6", and mounted to the left two bridge bolts. That put the switch right between/under the stem and the left bridge mount...
But the CRC2 mount looks like it would work better...less strain on the harness...it actually would mount below the clocks, without stretching the harness...I just made up a couple of plastic templates to see how it would work (both styles)...the switch has lots of clearance on top of the tank...and would fit close to the stem nut but still clear...
I'm with you on the jigsaw/drill fab...I have some 1/8" 304 SS that should work nicely...
Thanks! You've actually managed to stimulate me! (That's quite hard to do...)  ;)
Offline ProTeal55
  • Est1968.com
« Reply #7 on: May 28, 2006, 08:39:10 PM »
Sorry my chain isn't up to par, but it has been replaced since that photo.
If you are in search of some custom bracket, just make it yourself.
It isn't hard to take a piece of metal, and cut it to whatever pattern you want...
Seize the day buddy...
Offline puppytrax
« Reply #8 on: May 29, 2006, 03:45:11 AM »
I know; I'm a jerk...But I couldn't resist...   ;D :D ;)
Aha! You're the bloke with "JuNK"...I'll have to read that thread, and find out what that slimline gas tank is off of...   ;)
« Last Edit: May 29, 2006, 05:19:08 AM by puppytrax »
Offline Mule Train
« Reply #9 on: May 29, 2006, 08:52:25 AM »
this one came with the bike when i got it. I dont think it would be hard to make.
Greg
« Reply #10 on: May 29, 2006, 08:59:19 AM »
hey proteal
do you have a kill switch on your handlebars?
if so, what did you do for it?
Offline puppytrax
« Reply #11 on: May 29, 2006, 09:00:56 AM »
Yes, that's quite similar to the one I had, except mine was chromed. I mounted mine upside-down from the way yours is, so my switch was to the right of the two mounting bolts (next to the stem).
I'm making one up now. Taking time out for Yankees baseball, however.   ;D
Offline ProTeal55
  • Est1968.com
« Reply #12 on: May 29, 2006, 10:14:50 AM »
hey proteal
No kill switch on the bike at the momment.
I am going to wire something up when I get the bike back, prob just a simple
toggle or something under the gastank.
No prob bud, I can be one as well.
« Last Edit: May 29, 2006, 10:16:21 AM by ProTeal55 »
