Author Topic: PC stock rims with pits?  (Read 504 times)
Offline Really?
« on: February 10, 2012, 10:36:02 AM »
Hey folks, I promise I searched.
The rims on Beans do not look like they will clean up real well and I see people either paint or PC, not sure how much of one or the other.  So, if you are PCing the rims, what are you doing about the pits or gouges in the chrome?  Will they fill in or are y'all just living with the pits after a PC?  I would image paint not to last too long.  Talking bout the exterior of the rim.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Old Scrambler
Re: PC stock rims with pits?
« Reply #1 on: February 10, 2012, 11:36:36 AM »
Minor pits and scratches tend to be filled with the PC process..........especially if the rims is rotated during the baking process.  Major flaws in the metal should be sanded-polished to avoid sharp edges before the PC process.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Really?
« Reply #2 on: February 10, 2012, 11:41:59 AM »
Thanks Dennis!  So sanding the chrome is no big deal then and the chrome can be left on?  What if I need to sand a noticeable amount, is there not a brass or copper layer underneath?  If so, PC should be fine then too?  I do understand that you can PC wood if you really wanted to.  :)
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #3 on: February 10, 2012, 12:15:52 PM »
There are only 2 limitations to what you can powdercoat.
Can it take the heat of baking?
Can it hold a static charge so you can coat it?
If your guy is like my local guy, he will sandblast it anyway before coating. I'm removing the one or two heavy spots myself and blending them into the surrounding area, which he says he can fill. I may also get him to add a pinstripe as well, he says that is no problem.
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline Really?
« Reply #4 on: February 10, 2012, 12:41:32 PM »
Thank you Gonz!
