Author Topic: Pickup ramp?  (Read 2722 times)
Offline DaveInTexas
  • 1970 CB750
Pickup ramp?
« on: May 28, 2006, 02:07:29 PM »
maybe it seem pessimistic but this is a 36yr old bike.  What options are there for a lightweight ramp that will allow 2 people to get the bike into the bed of my pickup should it ever quit by the side of the road?
Commercially available preferred over plans.
Offline KB02
Re: Pickup ramp?
« Reply #1 on: May 28, 2006, 02:21:29 PM »
I've always liked the aluminum ramps that they seem to cary in just about ever bike shop I have been in.
http://www.handiramp.net/shop/category.asp?catid=38
« Last Edit: May 28, 2006, 02:26:41 PM by KB02 »
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
Re: Pickup ramp?
« Reply #2 on: May 28, 2006, 02:24:48 PM »
Tractor Supply sells a nice steel folding ramp for about $50.
Fonda Honda
Offline Gordon
  • 750K1, 550K2
Re: Pickup ramp?
« Reply #3 on: May 28, 2006, 04:25:22 PM »
I've always just used the trusty eight foot long 2x8, less than ten bucks at the depot.  Although if I were going to be doing a lot of bike loading and unloading, I'd probably get something that folds for easy storage.
Offline DaveInTexas
  • 1970 CB750
Re: Pickup ramp?
« Reply #4 on: May 28, 2006, 10:10:30 PM »
How do you get it up these ramps?  Several hundred pounds of dead weight; it will only need loading if the engine is sick of course.  Lots of upper body training?  I was thinking 2 people, maybe a cum-a-long?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Pickup ramp?
« Reply #5 on: May 28, 2006, 10:38:57 PM »
Park the truck facing down hill. Ramp not so steep now.
Dropping the back wheels into a slight dip works well to. No biggy, just push er up and in
 ;D
robbiec
Re: Pickup ramp?
« Reply #6 on: May 28, 2006, 11:16:59 PM »
My favorite are the alluminum ramps that have fingers at the top that keep it butted flat against the tailgate and attaching cables to stop it from sliding. The ones I used when I worked for a rental company were runged (is that an actual word?) so that if you had to stop partway, you simply let the tires sit in a slot. They also had a slight arc so that the initial push was steeper, but leveled off as you reached the top.
Okay, I just thought I'd check the link that KB02 posted and what-d'ya-know....those are the ones. Man. I loved those ramps,  :D It's the simple things that make your job better.
Damn. Now I have save and to go buy one. (Now I also know why my boss wouldn't get a pair for each truck....)  ;D
Offline mutters
Re: Pickup ramp?
« Reply #7 on: May 29, 2006, 02:23:18 AM »
 mate, I just bought a small electric boat winch for this very purpose and it works a treat.
 runs off  the truck battery and the operating switch is on a long  lead so you can operate it while you guide the bike on to the ramp
 brilliant!!
I know its only rock and roll,
but I like it...
Offline 74cb750
Re: Pickup ramp?
« Reply #8 on: May 29, 2006, 11:14:35 AM »
Here, in New England there is usually no problem finding a small hill, so
 I just used a 10 foot 2x10 board, but it is a pain
when it hangs out of the back of the truck.
I have a dirt ramp I use at home, but I probably
should get some of those aluminum ramps as I usually purchase 5-15 bikes a year
and have to truck them home.
maybe next year.
peace,
michel
Laugh at least once a day.
Life  $ucks, then you die.
Offline cb650
Re: Pickup ramp?
« Reply #9 on: May 29, 2006, 11:19:38 AM »
I have a 2x8 that is 8 ft long and a piece of angle steel on the end to hook into the bumper.
Been using it for 10+ yrs.
           Terry
Offline siter81
  • vintage bike junkie!
  • TOO MANY BIKES? NEVER
Re: Pickup ramp?
« Reply #10 on: May 30, 2006, 02:33:33 PM »
Try loading a ZL1000 Kawasaki into a elevated bed of a f-150. I broke down and bought a trailer with a drop gate.Life is so much easier now.
Siter81    :o :o :o
61 BMW R27 70 BMW R75/5  75 RD350
71 SUZUKI T500
75 CB750K5  Weisco 836, WEB CAM.DYNA IGN,KERKER,K&N,TAYLOR,GALFER,AGM ETC.
 01 HONDA VC11000C3 AERO.
74&75 DUCATI 860 GT'S
Offline Ernie
  • Dead again,could I get a
Re: Pickup ramp?
« Reply #11 on: May 30, 2006, 05:41:26 PM »
a small extension ladder works great.about 16 foot ir a nice angle ;D
Its all happening !
my 1978 CB550K.......>>>
http://gallery.sohc4.net/main.php?g2_itemId=4440
Offline Rushoid
  • Shameless
Re: Pickup ramp?
« Reply #12 on: May 30, 2006, 06:36:39 PM »
I also just use lumber. I got some aluminum ramp tops ($20/pr. at Home Depot) and put one on a 2"X10"X8'. They come with the hardware, just drill a couple of holes for the bolts. Rubber backing keeps them from sliding. I screwed a shorter 2X4 to the underside for extra strength. Easy push for me and a friend into the bed of a 4wd pickup. As long as the brakes work.  :D
Go Cards!! Go Colts!! Go Bucks!!
SOHC/4 Member #3452
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: Pickup ramp?
« Reply #13 on: May 30, 2006, 09:46:05 PM »
             Well, I don't have a truck, I've got a van. The way I load and haul is, I've got a WaveRunner
     trailer (removed everything off the topside of the trailer and installed a 4 x 8 foot sheet of 1/2"
     treated plywood w/ some front tiedowns. Bolted 3 plastic wheel chocks in place to rest the front
     wheels against (hauls 1 or 2 bikes). Bought 2 sets of end pieces from Wal Mart on clearance,
     attached them to a couple of 2 x 6 treated boards, added an electric winch from Harbor Freight
     and there you have it. Next step will definitely be a larger trailer, since I have to have a van or a
     minivan!                                          Later on, Bill
Member # 1969
Offline mcpuffett
Re: Pickup ramp?
« Reply #14 on: May 31, 2006, 01:16:08 AM »
i also have a van and use 2 8ft scaffolding boards to load my 750's  ;), i can get them in and out on my own no problem , mick.
Offline bill440cars
Re: Pickup ramp?
« Reply #15 on: May 31, 2006, 04:31:17 AM »
                     Only thing is, my van is a conversion van and there's not even enough room for Jame's
       (the handicapped young man that I work with) wheelchair. I use a cargo carrier that plugs into
       the hitch receiver for that. (got an adapter from JC Whitney that allows the carrier to be folded
       up out of the way, when not needed). Matter of fact, I brought home a Kawasaki F9 350 Big
       Horn  dirt bike on that once.
        Later on, Bill
Member # 1969
Offline scott_cb650
Re: Pickup ramp?
« Reply #16 on: May 31, 2006, 01:06:06 PM »
I bought some steel attachments to a 2x10 for mine.
I park at the end of the drive way. It makes for a less of a rise in the ramp.
These are also on sale for $40 if you have a Harbor Freight near by.
http://www.harborfreightusa.com/usa/itemdisplay/displayItem.do?itemid=44649
Why worry about tomorrow for tomorrow has enough troubles of it's own.
Offline GeoffT
Re: Pickup ramp?
« Reply #17 on: June 01, 2006, 05:50:56 AM »
I got free recovery service with my insurance so if I break down they can come pick me up take me home  ;D
Offline turtle
  • 1980 CX500 Custom
Re: Pickup ramp?
« Reply #18 on: June 01, 2006, 06:00:46 AM »
My better half does a lot of roofing work so a 4 metre plank or two onto his ute (pickup truck to you guys I guess) works reasonably well. There was a guy on our local tv (Aussie BC) the other night who had come up with a system where the sides of his ute tray converted to ramps.
http://www.abc.net.au/newinventors/txt/s1625350.htm
« Last Edit: June 01, 2006, 06:04:46 AM by turtle »
1972 CB350 Four
1977 CB750 K7
1979 Suzuki GT250 X7
1980 CX500 Custom
1980 CX500 Shadow
1981 CB900 Bol D'or
1982 CB750 F2
"If it ain't broke, don't fix it."
