Author Topic: Thoughts on a 75 CB 550F?  (Read 6702 times)
Re: Thoughts on a 75 CB 550F?
« Reply #25 on: February 24, 2012, 10:05:31 PM »
it might have been a bit cold there tews,it idles a little higher fully warm,audio on cameras also isnt real high fidelity,makes for a rattley sound.
Offline Accolay
« Reply #26 on: February 24, 2012, 11:11:12 PM »
Can I recommend an Ebay seller for a seat cover? "Gumtwo" in Canada makes very nice seat covers. Excellent quality product. The price is a little higher, but I believe their product is tops.
http://www.ebay.com/itm/CB550F-seat-cover-Honda-CB550-F-SUPER-SPORT-1975-77-198-/150635602254?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item231294e14e#ht_2182wt_940
1977 CB550F
Offline Vreihenmotor6
« Reply #27 on: February 25, 2012, 08:30:10 AM »
thanks for the heads up, hows the install? did you buy an install kit too?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #28 on: February 25, 2012, 09:24:14 AM »
Naw.. thats a F model fender!
Late model European F's had the four stays but I don't think any K's had 2 stays.
« Last Edit: February 25, 2012, 09:27:02 AM by LesterPiglet »
Offline Accolay
« Reply #29 on: February 25, 2012, 10:47:28 AM »
I will preface this with saying that as with anything else, you can spend as much or as little money as you want on your seat. The install is fairly simple, which is just like the original seat cover, but depends on the condition of the seat pan and the foam. Take a look at your seat pan and check if it is rusted or cracked at all. There are small triangular pointy catches punched into the seat pan edge metal that you stretch the cover over and hold the cover in place. Hopefully these are all in good shape and not rusted or broken off. This can be fixed too, but there is always that sweet spot where something is fixable, or if it would be the same amount of money to buy a used one in better shape.
Another part that may give you trouble are the chrome metal buttons for the seat strap which screw into the seat pan. The cover I recommended provides a new seat strap, but not the hardware. I have heard that you can find new hardware on Ebay or elsewhere if you keep your eye out if you want to go that route. The buttons on my seat pan were so rusted in place that I had to drill them out. I bought some chromed pan head hex nuts and bolts from Menards that looked nice and fit into the divet on the buckles.
I didn't catch if this is a running machine. So, the only other thing I recommend for you is taking apart the carbs and cleaning them (and do the 3000 mile maintenance too). The extent you disassemble them is up to you. http://s581.photobucket.com/albums/ss258/accolay_accolay/1977%20CB550F/Carbs/ It's not hard. Use brand new HONDA gasket sets, and use the jets and needles that came with that carb. Don't bother spending money on new jets and needles unless there is obviously something fishy a PO has done.
Good luck and enjoy that 550F.
1977 CB550F
« Reply #30 on: February 25, 2012, 04:12:14 PM »
thanks for the heads up, it is a runner, the muffler to header joint is fishy now and needs attention, I'll post up about that later
Offline cameron
« Reply #31 on: February 26, 2012, 02:03:05 PM »
Just FYI.. it looks to me like that there has a "K" model seat cover on it.. . unless 75 was different than later on.
You are going to need to consider the trim situation before too long... and how close to stock you want to stay.
1976 CB550F
« Reply #32 on: February 26, 2012, 05:10:14 PM »
good to know, the seat doesn't quite line up and its missing the latch to the seat lock
« Reply #33 on: February 26, 2012, 06:10:20 PM »
I may have an extra latch I will give you if I can find it.
« Reply #34 on: February 26, 2012, 09:26:44 PM »
that'd be sweet, thanks
