overflow problem?
Tubes, floats or intake valve.
Must be one of those, right?
All can be checked without removing carbs.... just pull the bowls. If you think you can get the o-rings seated again
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
I would have replacement float bowl gaskets on hand first... because of the expansion problem... but thats just me.
Given TWO CARB involvement, I would think either contaminant, as mentioned. or age-related. (cracked tubes). Dual stuck floats would be a funny coincidence, no?
