WARNING!!!!!!!!!!!!!!! WARNING!!!!!!!!!!!!!!!!!WARNING!!!!!!!!!!!!!!!!!!!!!!
You are gonna think I'm nuts, crazy, loco, insane, spacecase, and many others by the time you are done with this thread.
O.K. heres my brainstorm, or brainfart if you prefer. What about turning a head around so that the intake is on the front? I know about symetricality issues but they can be worked around. And about cam issues, but again, they can be worked around. My thoughts are thus:
1.) More air pressure in the front would put more air into the cylinder, thereby increasing combustion pressure.
2.) When riding, the cylinder head blocks airflow and the air has to make a 180 degree turn to go into the engine.
3.) Air passing the head on the way to the intakes pick up a bit of heat, lowering airpressure. (maybe not much but ?)
4.) In my configuration, airflow would continue in a fairly straight line, front to back.
5.) With a properly ground cam, every thing else would stay the same, points, etc. so no mods there.
6.) The stock airbox wouldn't work for obvious reasons, so V-stacks or pods would be the way to go.
7.) A carb rack can be easily designed to mount them to the front downtubes.
8.) Coil bracket can be easily relocated.
Now, before you immediately blow me off as a loon, just contemplate for a couple of minutes on the feasibility. I know you'll consider me a crackpot from now on but I get these crazy ideas and they rattle around my head til I do something with them. If I don't, they'll drive me around the bend for sure
Well, there you go, I await your condecension,
Peace and Long Rides,
Jeff
