Author Topic: 76' Honda CB500T Camshaft Timing Mistake Question.  (Read 3038 times)
Offline Pirate Gonzo
« on: February 25, 2012, 07:53:47 AM »
I replaced the head gasket on my 500T put it all back together but forgot to set the timing before hand  :-[. Is there a way to turn the camshafts with the cam chain on or am I ordering a new link? I have tried a few different things but had no luck in getting enough slack in the chain to turn them individually.
Any trick that anyone knows or just order a new link and cut it?
Thanks!
73' CB450T
76' CB500T
76' CB550K
77' CB750K
86' 49cc Spree
Offline grcamna2
Re: 76' Honda CB500T Camshaft Timing Mistake Question.
« Reply #1 on: February 25, 2012, 09:22:25 AM »
Pirate Gonzo,
     If you install the new link...you'll have to do the same thing anyway..... .
      I would pull the cam chain tensioner and it should give you enough slack to "slip" the cam chain one tooth at a time to gain you're valve timing;they can be a PAIN when you release the tension bolt on the tensioner assembly w/ all those different sprockets and such.... I bent an intake valve once trying to turn it over w/o being sure it was truly on the mark.It helped me to get all the cam chain slack taken up from the lower end w/ two lengths of thick copper wire..one through each large cam inspection port; I would also "put my own pre-tension on it" w/ different tools before I slipped the adjustment lock bolt loose on the cam chain tensioner.
  I had Fits over it  ::) for a whole a day...! until I got it to where it was "drawn up from the bottom" the way I liked it  :)...and then...I would finish by carefully installing the cam chain tensioner at a setting that I had decided on would work best...;as I installed it,I would hold tension on the cam chain as if "I" was the temporary cam chain tensioner ;)...and carefully keep tension on the unit as I transfered tension from my "special(round tip screwdriver type)tool" to the cam chain tensioner in one "somewhat"  :P smooth transition; as I did that last action of installing the cam chain tensioner that way....it would put tension on the cams & the entire chain(it's best to loosen up all the valve adjustment torsion adjustments to the SAME low setting before attempting this ;)) which would be just right to show me...after I had SLOWLY released the cam chain adj. bolt...THAT IS REAL IMPORTANT...SLOWWLLYYY(after I had evenly tightened all 4 cam chain tens.bolts to a low torque)if my timing was ON the mark...or not.. I had to repeat the above procedure until I was somewhat proficient at it. I was able to "slip" the cam chain on the Lower sprocket enough to get the engine "On The Mark"  ;D...it sure TAXED my Patience...,that much I'll say ! !  :'(..but I was able to complete it...after I walked away three times  :) 8);) :)
« Last Edit: February 25, 2012, 09:27:12 AM by grcamna2 »
