I think I have found the problem!! Searching the lines all up and down for a blockage, checking out this and that, I finally desided it was time to pull the petcock and check that out, too. As you can see by the pictures, I had two problems. The first being all the crap in the top of the petcock, the second being the lack of a tube for the "On" position of the petcock: Causing on and reserve to pull from the same location that was full of said crap.
A quick clean (a new o-ring) and alittle bit of gas and I should be up and running without a worry... well, almost without a worry.
According to my dollar store Vernier calipers, the yube openings in the petcock are either 4.5mm or 3/16" Which is it? Am I even close? Can I just get a piece of brass tubing from the hardware store and press it in and be good to go? Or do I have t make a stop by the local Honda shop? Can I even buy this tube seperately?
