Author Topic: Front n rear fenders on bikes..do you use them  (Read 8889 times)
Offline messeduptriple
Re: Front n rear fenders on bikes..do you use them
« Reply #25 on: February 26, 2012, 10:42:49 AM »
I just ordered a pair from fast past!! Thanks for the heads up guys! And was emailed back from them super fast with great information! That was sweet
Sent from my PC36100 using Tapatalk
« Reply #26 on: February 26, 2012, 10:45:15 AM »
A pair?
Anybody see making popcorn?!?
Offline KeithB
« Reply #27 on: February 26, 2012, 11:21:49 AM »
Just had a look at the front fender on my '80 XS650.
There is an insert of fairly stout metal that backs the mounting of the fender to the forks.
Seems unnecessary for "just a fender" so it's not a leap of imagination to conclude it's there for more than holing the fender on the bike.
Fork brace?...gee, ya think? ;)
Nanahan Man
Re: Re: Front n rear fenders on bikes..do you use them
« Reply #28 on: February 26, 2012, 11:24:49 AM »
A pair?
lol... Minus pair + one
Offline 72 yellow
« Reply #29 on: February 26, 2012, 11:27:14 AM »
Technically the only advantage is weight reduction.  You still need a fork brace to help keep the fork tube parallel under stress and bumps.  It is integral with the front fender.
Cosmetically, it is a fashion fad to remove fenders.  Nothing says the owner is a master customizer better than demonstrating the ability to remove parts from a bike.  ;D
No fenders pretty much restricts actual operation to only fair whether days, unless the rider wears some sort of baggie style suits to ward off water, from rain, sprinklers, saliva, honey wagon spillage, road kill, and general road spooge, etc.
Nothing says seasoned cafe racer better than having a stripe of road grime running down your back or gritting between your teeth.  Chicks love that, as well as the smells of having your nose an inch from any road surface debris imaginable.
All my bikes have fenders.  And, the one I got with them stripped off I restored, as well as replacing the other dumb ass "racer-look alike mods" made to the bike.
What exactly is spooge and how did it get on the road ?
Offline BeSeeingYou
« Reply #30 on: February 26, 2012, 11:33:27 AM »
from the urban dictionary
   n. goopy or viscous substance similar in texture to cum
   v. to cause a goopy substance to end up on an item or person.
   That should be enough reason to keep the fenders on the bike. ;D
« Last Edit: February 26, 2012, 11:35:29 AM by srust58 »
Offline 72 yellow
« Reply #31 on: February 26, 2012, 11:44:27 AM »
So should I decontaminate to bike before I put it in the garage?
« Reply #32 on: February 26, 2012, 12:23:26 PM »
Depends on which parts of the bike you wish to fondle.  I estimate the fenders (excluding the fork brace) are to help keep the rider clean of roadway substances.  Bits of bike that are incidentally kept clean is just an added bonus.  If your bike drips in the garage, you could use a catch pan rather than cleaning it before garage entry.  ;D
Offline BeSeeingYou
« Reply #33 on: February 26, 2012, 01:44:02 PM »
I would have to admit that I am somewhat mystified by the idea removing the front fender to improve the looks of a bike.  What's better looking....a nice chrome or painted fender, maybe even cut down a bit....or some nasty old tire tread?
« Last Edit: February 26, 2012, 03:01:04 PM by srust58 »
« Reply #34 on: February 26, 2012, 03:56:32 PM »
Cool, link me to some hard facts about the stock brace. Not some irrelevant analogy or he said she said stuff. If the stock brace was what you say it is, why are there no aftermarket ones similar? This thing has no rigidity, and that's not why it works. Symbiosis, yes, stack 5 braces together then it will do something. Like I said link me to some hard facts, studies, etc. I will admit when I'm wrong but don't come on here spouting out stuff just because it's attune to your style. And let me again add I never said a brace wasn't needed, I'm saying the front fender is just a fender.
Sorry mate but its become obvious to me that when you make up your mind, regardless of if you are correct or not, it matters not what anyone says. Lloyd {TT} is an engineer, he is also 100% correct. "Sprouting out stuff", really, that seems to be what you are doing, how much pressure do you think it takes to twist that brace?, even if it is as low as 10 pounds of pressure it will make a difference, that should be obvious to anyone.
Offline donny
« Reply #35 on: February 26, 2012, 05:49:54 PM »
 I removed the fenders on one of my bikes for pounding out dents & paint, and never bothered to replace.  I can't determine any different handling than the other bikes with a front fender.  I had fork brace to attach, but I still can't feel any difference.   Yea, everyone thinks now I'm a chopper guy.
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
« Reply #36 on: February 26, 2012, 06:22:37 PM »
 The fact that Honda decided it could live with rubber mounts may indicate something....
« Reply #37 on: February 26, 2012, 06:39:58 PM »
Doubts based on what mechanical principle or knowledge?
The fender is rubber mounted to one fork leg so it isn't that structured to remove minor postition shifting between the two fork legs. Any flex or give past the clearance of the steel/aluminum trubes is between the clamped  lower tree and the clamped axle. So I too have my doubts as to whether the rubber compresses fully within the clearance or play of lowers/fork tubes to actually take advantage of fender structure. In theory it adds something but I doubt it matters being so small. Yea, I too have my doubts.
I actually did do some tests on the effectiveness of the rubber mounted stock "fork brace" the last time this subject turned into a popcorn-fest, and found it to be essentially worthless. By removing the rubber grommets, and sandwiching the FENDER MOUNT with washers, it stiffened up the resistance to twisting by 20%, as I recall. A real fork brace was worth 80%, based on the same test methodology.
« Reply #38 on: February 26, 2012, 06:48:15 PM »
 If you cant trust a Honda engineering division, who can you trust?
« Reply #39 on: February 26, 2012, 06:49:57 PM »
Trust noone
« Reply #40 on: February 26, 2012, 06:55:05 PM »
wow...that's crazy
Offline 72 yellow
« Reply #41 on: February 26, 2012, 07:12:17 PM »
Then call the Hazmat team to remove and dispose of the drip pan?
Offline bikerbart
« Reply #42 on: February 26, 2012, 08:40:25 PM »
I want to put a mudflap on my fender,even more protection,boy will I be a dork. ;DHere in the pacific NW you'd be a real poser not to have a friggin fender,it would just tell us how much you DONT ride. ::)
Offline MoMo
  • Ride like you're invisible
« Reply #43 on: February 27, 2012, 02:22:41 AM »
[quote The fact that Honda decided it could live with rubber mounts may indicate something....]
Likely they did not want it to be a structural part and crack something over time. I suspect initially it was rigid, until testing proved that unwise. Often enough things engineered into a mechanism are a result of design oversights. If they intended it to be a fork brace, well it's no wonder they lost the war :)
[/quote]
You are right, Honda went to the rubber mounts to minimize cracked fenders.   Speaking of crack, this thread is turning into a crack and popcorn festival :D....Larry
« Reply #44 on: February 27, 2012, 10:11:07 AM »
I do enjoy the information though..good popcorn
