Author Topic: Mistake while lapping valves - need advice  (Read 3071 times)
Offline AbbyRider
« on: February 26, 2012, 01:06:34 PM »
Hello all. This afternoon I spent a good solid hour lapping my valves. During engine dissassembly I had bagged and tagged everything, inculding the valves: sequentially numbered for intake and exhaust. When I began to reassemble, I was horrified to discover that in the process of lapping, because I had the valve seats facing up, I had lapped the #1 valves to the #1 seats, #2 to #3 etc. So my question is - seeing as how I've mated the valves to the seats, even thought they're not in the original sequence, am I okay to leave as is? Or should I start over with mating the original #1 valves to the #1 position and so on? I'm not adverse to more work, but I'm worried that I'll be taking more meat off the seat unecessarily. Thanks.
'98 VTR1000 Superhawk
'78 CB750F
'77 CB750F (in the works)
'81 KZ650 sitting in pieces in my basement
bollingball
Re: Mistake while lapping valves - need advice
« Reply #1 on: February 26, 2012, 01:49:14 PM »
I would think it might make a difference at the stem where it contacts the rocker. Maybe some one can say I'm not 100% sure
                                           Ken
Offline Bob3050
« Reply #2 on: February 26, 2012, 02:14:03 PM »
If after lapping the valves you can see a good sealing area that is in the middle of the valve face, not too high or low, then you should be fine. If the sealing surface is too narrow or too wide or too high on the face or too low then you need to address the problems which would probably mean having the seats re-cut.
Bob
Offline AbbyRider
« Reply #3 on: February 26, 2012, 03:22:08 PM »
Thanks for the replies. I went ahead and reinstalled springs and then did a leak test and they appear to be sealing okay. So I'm going to go with it. If anyone else has any further advice, feel free to post still, as I'm still awhile away from putting the cylinder head back on.
'78 CB750F
Offline magconpres
« Reply #4 on: February 26, 2012, 10:48:34 PM »
The other thing to consider is the wear on the valve guides.  Ideally, you want the original valves in their original guides.  Probably not a big deal though.
1975 CB400F, stock,  on the road
1975 CB400F, ran when I parked it. Cafe Racer bound
1986 TLR200 commuter and trail bike when with the kids...90MPG!
1986 TLR200, Vintage Trials build up coming
1986 TLR200, Not sure what to do with this one...Vintage Trials Super Moto?
2004 GasGas 300EC...my enduro racer
2004 Sherco 290...Trials bike
2004 CRF70... Son's ride
2006 PW50 ... Daughter's ride
1982 XL500R (04 XR250 front end)...my DS bike.
« Reply #5 on: February 27, 2012, 01:42:47 AM »
id put them back into the original locations and relap.
Offline trueblue
« Reply #6 on: February 27, 2012, 01:51:22 AM »
Bob
+1 it is the seats that matter more with how they wear than the guides, if you recut the seats it doesn't matter which position they are placed in, if the seats look good just run them.
1979 CB650Z
Offline fmctm1sw
« Reply #7 on: February 27, 2012, 10:46:29 AM »
I would place the valve in the same spot that I lapped it in.  I'm a little overboard sometimes though...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
