Author Topic: Vintage sidecar rebuild - new video  (Read 154925 times)
Re: Vintage sidecar rebuild
« Reply #375 on: May 11, 2013, 06:50:13 PM »
Brian, have you verified your ignition advance? The "wall" you keep running into at 7K RPMs may have nothing to do with the Web??
Offline Tintop
« Reply #376 on: May 12, 2013, 07:22:19 AM »
Advance is currently at 37 degrees, set with a strobe.  It's one of the things I'm thinking about changing.  Likely try 35.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Tintop
« Reply #377 on: May 15, 2013, 08:15:37 PM »
Did some checking on the timing scotty, and concensus was leave as is for now.  This is what I was running last year, and it would pull past redline.
Not convinced the idle is right, think it is a bit rich yet given the reaction to opening the air corrector(s).  I'll work on that before the 1st race (16 days to go ;D).  Also looking at the plugs again, think it's actually tending lean @ WOT.  It's very close though, so I'll try a 180 air (from 185) in practice and see what I get.
Swingarm is rebuilt, and shim'd over slightly to improve chain alignment.  With the amount of play that was there it's no wonder it was an evil handling beast at 'test & tune'.  Thinking turn 1 @ Shanny might be flat now.  New clutch plates are in, and all the internal linkage checked.  Denis @ CMR has modified the shifter rod attach position for me.  Feels like it should be much more positive now, with significantly less play.
77 CB550 Cafe build
Offline Tintop
« Reply #378 on: May 16, 2013, 08:31:30 AM »
Posted a reply on the VRRA forum about 'who's going to the 1st R.A.C.E. event this weekend.  Said I was planning on going to watch, unless someone had a spare F2 sidecar I could use.  Got a reply to call. 8)  L/M this morning, but given the race(s) start on Saturday, and the rig is 4+ hours away, and I'm not sure I'd even have a passenger, this not likely to happen.  But we'll see.
77 CB550 Cafe build
Offline Tintop
« Reply #379 on: May 16, 2013, 10:15:15 AM »
Going to P/U the F2 tomorrow 8), but it's an 9 hour round trip. :(  Still not sure I will have a passenger, but messages have been sent.
77 CB550 Cafe build
« Reply #380 on: May 16, 2013, 05:10:31 PM »
I am confused, #239 you have been working on, is she not an F1 or F2 sidecar rig?
Why the need for another rig? Is it not VRRA eligible?
« Reply #381 on: May 16, 2013, 06:24:57 PM »
I suspect its not ready to be raced David... ;)
Offline bear
  • Leeton in Australia
« Reply #382 on: May 16, 2013, 06:31:31 PM »
Brian's chair is a classic sidecar. Period 3 I think :-\
The meeting he is referring to would be for moderns I'm assuming.
Brian
« Last Edit: May 16, 2013, 06:35:11 PM by bear »
Offline Tintop
« Reply #383 on: May 16, 2013, 08:55:56 PM »
Bear is correct.  This weekend's racing is for modern F1 & F2's.  I've been loaned an F2 (GSXR 600), and possibly have a passenger (rookie), as my regular one can't make it.  Only reason for doing this is it's on the same track as I'll race #239 in two weeks, so some extra seat time.   Will get grid'd last, and we'll see were I finish if things go to plan.
77 CB550 Cafe build
« Reply #384 on: May 16, 2013, 09:21:52 PM »
oooooooh, those modern chairs are dead sexy...... 8) ;)
Offline Tintop
« Reply #385 on: May 17, 2013, 08:26:53 PM »
RR, this one is the ugly sister.
Spent today draining the winter storage antifreeze, and rerouting / reconnecting rad hoses in the proper order.  $2 for 4 litres of distilled water, $20 for 12oz of Water Wetter. :o  Only used about 2oz of WW, so given #239 is air cooled, probably now have a life time supply. ::)  Didn't get out today, still need to make numerous adjustments, as it's setup for someone 6+" taller, & 100lb heavier.  Not inspiring a lot of confidence at this point.  May just park it, if I don't feel more comfortable, and confident in it/with it.
Last year's F1 Champion is out with an F2 MRE he brought over in the fall.  It ran the IOM in 2011.
77 CB550 Cafe build
« Reply #386 on: May 17, 2013, 09:32:42 PM »
Got any pics..?  ;)
Offline Tintop
« Reply #387 on: May 19, 2013, 01:57:01 PM »
I've got a few I'll post later RR.  In the end decided not to run it.  Couldn't adjust the brake & shifter pedals enough to suit me.  Given I was going to have a rookie passenger onboard, this was not a safe situation for either us, or the other sidecars.
77 CB550 Cafe build
Offline Tintop
« Reply #388 on: May 19, 2013, 07:50:31 PM »
Here you go RR.....
MR Equipe, bike that has run IOM & came from Ireland.  New owner is last year's SRA F1 champion, and is planning on running IOM next year.
Shelbourne (don't know the age, but an older one)
The ugly sister.  Originally ran an air cooled engine, hence all the odd ducting. ::)  Besides the brake & shifter issues, the stock air box made for a long reach to the bars.
77 CB550 Cafe build
« Reply #389 on: May 19, 2013, 09:32:34 PM »
Thats not too ugly Brian, just needs a decent paint job, would have been fun to ride.... ;)
Offline Tintop
« Reply #390 on: May 20, 2013, 06:22:23 PM »
Actually the paint job was probably the best part RR. :( ;D ;D ;D ;D
77 CB550 Cafe build
« Reply #391 on: May 21, 2013, 02:53:23 AM »
 ;D I see, not real good with its clothes off eh.... :o  ;)
« Reply #392 on: May 21, 2013, 03:51:29 AM »
Needs a new solution for the air box to improve controls access and a taller rider. Air box makes it look less than fully baked. Is the side car venting for the radiator? Is the venting in the main body needed, or does it just add drag?
Offline Tintop
« Reply #393 on: May 21, 2013, 04:58:37 PM »
RR it's a rat's nest underneath.  Lot's of bodged fixs, one on top of the other.  Can understand having to do that during a race weekend, but should have been cleaned up before the next.
That was one of my fitment issues RAFster122S.  The big air box made the reach to the bars difficult.  If you look at the MRE & Shelbourne they both have much lower profile air boxes.  That's what this bike needs.  As for the front duct...it was originally fitted with a 900 Kawasaki, and there was no rad.  Think it was left to aid air flow to the box.
Interesting update - was going to return it tomorrow, but was told to hold on to it, and make what ever changes I want so I can race it later in the season. 8) 8) 8)  It's been For Sale for awhile, and the owner won't be racing it again do to health issues.
77 CB550 Cafe build
  • Moderator
« Reply #394 on: May 21, 2013, 10:49:01 PM »
Looks like it could be a very busy year Brian. ;D ;D ;D ;D ;D ;D
Offline Tintop
« Reply #395 on: May 22, 2013, 06:32:18 AM »
Unless I find some sponsorship Sam, doing the 3 USA rounds of the F2 races is a no go.  However there are 2 more races up here at the end of the summer.
77 CB550 Cafe build
Offline Tintop
« Reply #396 on: June 02, 2013, 06:18:45 PM »
So the race weekend was not the best, a good news, bad news couple of days. :(
Lots of stuff fracturing from vibration, but did some track repairs....part of the coil mount (safety wired broken piece) / tach mount (duct tape ;D) / fairing support bar (welded) / GoPro mount.  Camera came off in the 1st heat race, and landed in my passenger's lap.  Couldn't figure out what he was doing, until we came onto the straight.  Showed it to me, then stuck it in his suit. :o
Had an exhaust clamp come loose in practice, causing sever backfire on over run.  Tightened the clamp, then had the other one go in the heat race.  Removed the exhaust to find the copper gaskets had been destroyed.  Borrowed some used ones of a different construction, and that fixed the issue.  Did a compression test at that point, 150 in the both. :)
Good news, we now know we've got the speed to run with the front guys.  However the chair wheel is locking under hard braking which is causing some interesting handling issues. ::)  In the final started 3rd, passed for 2nd on the straight on the 1st lap (improved standing start 1st lap from 1.38.6 to a 1.37.7 ;D).  However coming into the turn at the end of the straight (100mph?) chair wheel locked.  Bike danced around, and by the time I got it head in the right direction again my exit point was now going to be 10ft off the track.  Decided going off sideways wasn't good, and drove it straight off.  Good thing there was alot of run-off.  However, it was a rough ride, and got airborn at least once. ::)  Got stopped, but on returning to the track (off line) decided it didn't feel right, and the platform looked like someone had dumped their lawn cuttings. ;D ;D  Parked it and called it a weekend.  I'll take some photos tomorrow of some of the carnage, and if I can edit it, some video.
« Last Edit: June 03, 2013, 05:15:03 PM by Tintop »
77 CB550 Cafe build
Offline FuZZie
« Reply #397 on: June 02, 2013, 06:42:18 PM »
Don't press your luck, either go over it top to bottom or send it back!
Offline Tintop
« Reply #398 on: June 02, 2013, 09:39:10 PM »
Not sure what I'm suppose to send back. ???
All body work is getting removed / frame will be getting a complete crack check / chair wheel will get stripped to the spindle, and get a new tire (old flat spotted now :(), and brake modified.  Some engine work to do re the clutch, and starter gear.
77 CB550 Cafe build
  • Moderator
« Reply #399 on: June 03, 2013, 12:29:41 AM »
Perhaps Douggie is thinking F2 Brian.  :-\  If it was the Yam, what have you changed since your last outing that could have caused these problems?
Sam. :)
