It's the chair wheel load variations, combined with the harder braking from the increased speed, that are causing my problems now.
Quite a few have a similar set-up to mine Brian. That said, they all came from the same builder. He'd build one, race it for a season, and then sell it on and build another. Some others (different builder) only run a front and rear brake, no chair. Most of those are running a drum rear.
I've gone through the rules again, and there doesn't seem to be any restriction on linking, just what components you can use. So with that in mind I'm going to look at changing mine to linked rear & chair with a bias adjuster between.
