Author Topic: Vintage sidecar rebuild - new video  (Read 154546 times)
Offline Tintop
Re: Vintage sidecar rebuild - new video #449
« Reply #475 on: July 20, 2013, 03:30:36 PM »
Whats it measure around a inch?
Yeah about that.  The point were the inside down tube meets the front cross member has gone from 3 3/4" to 4 1/4", so time to change the shocks and get it back down to 3 1/2.  That will definitely help front end grip.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Tintop
Re: Vintage sidecar rebuild - revised video #476
« Reply #476 on: July 20, 2013, 06:52:58 PM »
So here's the my 1st attempt at a finished video.  The next one from Mosport should be fun, I'll have 2 cameras to work with. :)
2013 VRRA Summer Classic P2 Sidecar Final #239
« Last Edit: July 20, 2013, 08:26:53 PM by Tintop »
77 CB550 Cafe build
Online scottly
« Reply #477 on: July 20, 2013, 07:57:16 PM »
Great video Brian!
Offline Tintop
« Reply #478 on: July 20, 2013, 08:31:56 PM »
Thanks scotty.  I'm waiting now for the letter from Pat Benatar's lawyers re copyright. ;D ;D ;D ;D ;D
77 CB550 Cafe build
Offline Tintop
« Reply #479 on: July 31, 2013, 03:07:03 PM »
P/U the sidecar from Denis @ CMR today.  As usual they did a great job, and Byron did some beautiful welds. 8)  They made a plug to fit the gap, welded it in, then added saddles over that.
Did discover that the previously repaired area at the rear shock is starting to crack again. :(  Going to have to add some strength to that area.  Have to see what can be done without having to modify bodywork.  In the mean time got busy putting everything back on, that had been removed to fix the frame.  Next up, pull the front shocks, set the frame at the correct ride height, and measure for new shocks.
77 CB550 Cafe build
« Reply #480 on: July 31, 2013, 03:50:06 PM »
That is some nice welding, very clean work and post welding cleanup.
Offline Tintop
« Reply #481 on: July 31, 2013, 07:02:52 PM »
I'll pass your comp on to Denis & Byron.  It's probably the strongest part of the whole bike now, and last place I'll ever look for cracking.
77 CB550 Cafe build
Offline Tintop
« Reply #482 on: August 03, 2013, 11:54:09 AM »
Did some more work on changing the front ride height.  Got some turnbuckles from Home Depot and installed them in place of the shocks.  Set the length to give me the ride height wanted, then put blocks under the rear & chair wheels, and a scale under the front.  Weighted the front end static (208) / with just me (249, ~20% increase) / and with a passenger (272, ~10% increase).  Determined that the old shocks are Hagon.  Sent them an email, and they can supply ones at 320mm.  So loaded sag required would be 15mm, with no more than 1 1/2" of additional travel.  Looks like this would mean progressive springs.
Also made a template for the additional bracing required to strengthen the right side rear shock mount area.  Should have that maded, and welded in by the end of next week.
There should be a new member joining the forum shortly.  Sold one of my 750 engines to another sidcar guy.  He is going to be installing it in a Baker F2 chassis, so he can run in our P3 class. 8) ;D ;D
77 CB550 Cafe build
Offline Syscrush
  • Sold. :(
« Reply #483 on: August 13, 2013, 03:47:28 AM »
Why progressive springs instead of just stiff?
Offline Tintop
« Reply #484 on: August 13, 2013, 06:17:32 AM »
Ordered shocks today for both front and back.  Most of Hagon's lineup come with progressive springs Syscrush.  That said, I've been talking to British Cycle Supply (Cdn Dist), and they have another shock that has straight rate springs.  Basically I've been racing on springs, as the shocks no longer have any dampening to speak of. :o  The ones going on will have 100lb springs (F), about 10% less than the previous,  The rears are 110lb.
Sent my polished rear rim out (not to my normal guy) to have some wobble taken out.  He's had it 3 weeks, and I find out last night he didn't do anything. :(  Says the 2mm runout is within limits.  What the f*ck, maybe for a street bike, but not a race bike, and certainly not a sidecar with the side loads they get.  Will never send anything to him again. >:(
77 CB550 Cafe build
Offline FuZZie
« Reply #485 on: August 13, 2013, 08:07:36 AM »
To bad you couldn't put his sorry ass in the side car for a few laps... either change his mind or try to help him off in the turns.  :P
Offline Tintop
« Reply #486 on: August 13, 2013, 01:48:58 PM »
Worst of this situation FuZZie, is that rim has a new tire on it.  I put 2 heat cycles on the wheel at the spring 'test & tune' to scrub it, then removed it, to save it specifically for Mosport. :(  I'll use my worn one (2 race weekends) for the 1st two practice sessions on Friday.  There's 1 1/2 hours between the 2nd and 3rd, so I'll change wheels then, and try it.  If it sucks (likely), I've got 4 hours between the 3rd & 4th sessions to do a tire change.
Did some checking, seems 2mm (0.07") is the 'not to exceed' limit for run out.  That said the other wheel has .5mm / .02 runout.  After the weekend I'll send it to Brian Henderson to have it brought into spec.
77 CB550 Cafe build
Online scottly
« Reply #487 on: August 13, 2013, 07:17:27 PM »
Sorry about the slight thread-jack, but for Relay reasons, just how far from Kingston is the Mosport track? ;)
Offline Tintop
« Reply #488 on: August 13, 2013, 07:42:48 PM »
Not a problem, don't consider it a highjack scotty.  A little over 2 hours by Highway 401.  It's just north of Bowmanville, ON.  Does the question mean that GZ might make it to Mosport (now Canadian Tire Motorsport Park :(, but I refuse to call it that!).  That would be cool, he could ride the sidecar again. 8)  My races are Saturday & Sunday @ ~11:30.  bwaller's are the race before mine, he has another about 1:30 (different class).  hrcscott & timv are also racing.
77 CB550 Cafe build
Online scottly
« Reply #489 on: August 13, 2013, 07:52:43 PM »
I'm doing my best to get GZ there by the weekend of 8-24..
Offline Tintop
« Reply #490 on: August 13, 2013, 08:26:19 PM »
Do I interpret that to mean 'you' personally.  That would be great to meet in person. 8) 8) 8) 8)
There's a band Saturday night (were great last year), and I'll make sure there's some beer.
77 CB550 Cafe build
Online scottly
« Reply #491 on: August 13, 2013, 08:36:36 PM »
Unfortunately, the Star Trek transporter isn't functioning right now, or I would do the DC to Kingston ride. ;)
« Reply #492 on: August 14, 2013, 04:07:44 AM »
Brian, Tim V's dyno guy cancelled his session. Can you suggest a shop? PM Tim directly or myself.
Offline Tintop
« Reply #493 on: August 14, 2013, 05:25:38 AM »
eamil sent with suggestions this AM bw.  I'll also cc TimV just in case.
Hummm.....seems the electronic turbo pigeons, are faster than I can type a reply here.  Tim's got the info I sent you. :o
« Last Edit: August 14, 2013, 05:33:24 AM by Tintop »
77 CB550 Cafe build
Offline Syscrush
  • Sold. :(
« Reply #494 on: August 15, 2013, 02:03:42 PM »
You've built many more race machines than I have, and I don't doubt that you know better than I do what should go on 'em, but the idea of progressive-rate springs just makes no sense to me at all.  I mean, it's basically a guarantee that the damping and spring will be mismatched.  I would never run a progressive spring, but lots of people who ride better/faster than I ever will do run 'em...
Offline Tintop
« Reply #495 on: August 15, 2013, 03:01:11 PM »
Re Hagons and progressive springs, the operative word Syscrush was 'most'. ;)  The Hagon shock / spring sets I ending up ordering from British Cycle Supply are essentially custom order, but made up of off the shelf parts.  Shocks have the eye sizes & lengths (different) I require for the front and back; and straight rate springs in the rates I need.  Nice thing about Hagon is they will do a N/C spring change if the rate isn't right. 8)  So we get to try them @ Mosport, and if we decide that they're not right, they can be changed.
77 CB550 Cafe build
Offline Tintop
« Reply #496 on: August 19, 2013, 03:23:28 PM »
Almost ready to starting loading for Mosport.  Hagons came today, and were a bolt on.  Many thanks to Martin @ British Cycle Supply.
This is the brace I had added to support the frame were it was cracking from shock stress.  MIG'd all round, and on both sides were it joins the original upper shock mount.
77 CB550 Cafe build
« Reply #497 on: August 19, 2013, 05:50:15 PM »
I'm glad you're all set, good luck while we're on the topic. The S65 is ready too!
Offline Tintop
« Reply #498 on: August 19, 2013, 06:02:52 PM »
Looking forward to seeing the S65.  Has Deb been practicing her MotoGP riding style?  You should have some fun on Tim's P1.
77 CB550 Cafe build
Online scottly
« Reply #499 on: August 19, 2013, 08:52:25 PM »
Brian, it looks like the top of the shock is hitting the support? Not a good thing, IMHO.
