Author Topic: New Clutch Cover Bolts  (Read 938 times)
Offline wedoo2
« on: February 27, 2012, 06:03:42 AM »
74 550.  I am wanting to replace the stock screws with hex bolts for the clutch cover.  I have a new gasket but the screws will not stay tight and have been off and on so much that they are getting stripped.  Makes my baby bleed on the floor.
Anyone know a vendor?
Some days the sun is too loud.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
Re: New Clutch Cover Bolts
« Reply #1 on: February 27, 2012, 06:30:35 AM »
local hardware store will carry what you need.
or you can order from "bolt depot", look under "socket products".
searching for a dr350se
bollingball
« Reply #2 on: February 27, 2012, 08:53:05 AM »
Are you sure the holes are good. They usually get stripped before the bolt. I would clean up the hole before putting in the new bolts.
What about allens? There are lots of places that sell complete allen kits for our bikes
                                            Ken
« Last Edit: February 27, 2012, 08:56:35 AM by bollingball »
Offline wedoo2
« Reply #3 on: February 27, 2012, 10:41:39 AM »
I actually meant allen bolts.  Any ideas?
Online CycleRanger
  • No comment about being an
Offline becken
« Reply #5 on: February 28, 2012, 06:47:36 AM »
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
Offline lucky
« Reply #6 on: February 28, 2012, 07:15:10 AM »
You mean METRIC Allen SCREWS.
You call them bolts when they are larger than 1/4 inch diameter.
Offline buffaloejon
« Reply #7 on: February 28, 2012, 12:00:39 PM »
Negatory, you call them bolts when they use a nut instead of a threaded hole ;)
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
76 CB750K
http://photobucket.com/buffaloejon
