Author Topic: Autozone replacement flasher relays  (Read 13359 times)
AntiRiceCRX
« on: May 30, 2006, 10:00:20 AM »
Will those little 2 dollar 2 prong flasher relays work for my blinkers?? Mine light up but dont flash, i bought the two prong relay for like 2 bucks at autozone and it didnt work, they wouldnt even light up....is it supposed to work and i have a wiring problem? i shouldnt since wiring is untouched on this bike.
Offline Bryan Boyle
  • SOHC4 #47 ...one of the Old Pharts
    • The Other Hobby: Restoring Lotuses
Re: Autozone replacement flasher relays
« Reply #1 on: May 30, 2006, 11:17:09 AM »
I'd go for the 17. or so electronic flasher....replaced on all of my bikes...and no problems. (the mechanical ones depend on having enough juice in the system to heat the bimetalic strip to break the contact and so forth.  The electronic ones work down to about 9 volts or so...and are pretty constant in their action (ie same speed
whether idling or full tilt boogie...
Bryan
SOHC4 #47
Proud member since 1994, active on and off
Commercial Pilot/Flight Instructor-Instrument/A&P
Morrisville PA
'63 CA95, '64 CA77, '73 CB350F, '73 CB350F, 2 Lotus Europas and Lots of Parts All Over The Place
Offline gkw120649
« Reply #2 on: May 30, 2006, 11:25:21 AM »
Try the DOT-552 flasher.
1977 CB-750 K
1978 CB-750 K
Offline STLrocker
  • whiskey bent and hell bound
« Reply #3 on: May 30, 2006, 11:27:04 AM »
i've used a few of the mechanical ones from autozone withut problem. you just gotta be sure to get the right one.
AntiRiceCRX
« Reply #4 on: May 30, 2006, 12:06:10 PM »
yea i had the DOT 552 and it wouldnt even light them up, tho i have a bad battery and didnt have the bike running....ill go turn in the 3 prong and get the 2, cause i got the 3 when i saw the extra wire hanging down...
« Reply #5 on: May 30, 2006, 12:26:34 PM »
I have the electronic flasher from Autozone and it worked no problem....forget which one I bought but I seem to recall it may have said 12V on it or something like that. Works great. Good luck,
Andy in Boston
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #6 on: May 30, 2006, 12:27:36 PM »
Someone in another post "sorry. couldn't find it again" put up this link as a solution to after market signal blinking problems.
Light goes on, but no blinky............
I had tried different bulbs with no success.
I bought one of these  http://www.customled.com/PRODUCTS/FLASHER_RELAY/flasher_relay.htm for $19.99
Hooked it up to the 750 and now have working signals.
Thanks to who ever put up the link. Just ordered another one for the CL350.
Offline gkw120649
« Reply #7 on: May 30, 2006, 12:55:28 PM »
This electronic flasher will work.
Tridon Stant 12 volt 3 terminal electronic flasher EP35.
It is a 3-prong.  I did blow the main a couple of times until I got it hooked up right.
Greg in Chicago
1977 CB-750 K
1978 CB-750 K
Offline Chris Schneiter
    • Christopher Schneiter Photographer
« Reply #8 on: May 30, 2006, 01:10:40 PM »
When I got my '76 CB750, the guy I bought it from had mounted new blinkers, but they still didn't work. I replaced the flasher, but no dice. Normally, I believe the lights are supposed to be grounded to the frame by mounting. There was only one wire coming from the blinker. when we hooked that to the proper hot inside the headlight, it came on but didn't flash. We ended up running a separate wire to ground it to the frame (ran a wire from the pivot bolt inside of the headlight to a mounting bolt on the speedometer, then hooked the blinker ground to that) to make sure the light was grounded. Then it worked!
All this backyard engineering is why each of our bikes are unique. Regardless of whether our solution was right, doesn't really matter. It was a ground problem, and we grounded it!
CB750 K6
« Reply #9 on: May 30, 2006, 02:01:59 PM »
If the turn signals are staying lit, you have a ground problem. If they are not lighting at all you may have another lighting problem. Check that you have 12V going to that flasher. You can do that with a meter, or you can use a bulb and two wires.
Diggity
« Reply #10 on: May 30, 2006, 05:05:33 PM »
I'll agree with the other guys --- Ground problem --- I haven't got mine on the road yet, but I'm making everything safe.  I got a new -used- horn for it , didn't work, ground problem. Cleared that up, then the blinkers wouldn't work, ground problem.  My bike has a ground wire attached to each side of the headlight pivot bolts. I cut both wires and ran them to the frame, Fixed it.
By the way 550F
prsman23@hotmail.c
« Reply #11 on: May 30, 2006, 05:20:12 PM »
I used the two prong el cheapy one from autozone and it worked great on my 650. I think it was around two bucks.
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #12 on: May 30, 2006, 06:48:39 PM »
On my 550, I have 2 wires from each rear turn signal - hot & ground.  Three on each front, turn, running & ground.  My grounding is thru wires, not the mount.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
« Reply #13 on: May 30, 2006, 07:03:38 PM »
You do not have to go crazy looking for a ground, any part of the frame will do. Just not a part that is rubber mounted.  ;D
Offline 8 Track
  • 1976 cb750
« Reply #14 on: May 30, 2006, 07:16:38 PM »
My flasher's out of a '94 impala ss.  Works great.
My dog loves me for the person I try to be.  Either that or he's hungry.
huntman58
« Reply #15 on: May 30, 2006, 07:48:06 PM »
hm may have to try a different flasher. mine is slow at ideal or slow speed but normal at faster rpm's .I am using some trailer lights on my side bags so I have three tail and brake lights with three running light . using a stander old trailer light three way bulb with a cheapo flasher from Kragens . I did have to also install a light converter to run all the light it is a set up for pulling trailers when tow has separate run,brake and turns and the trailer has the two way bulbs . it has worked for years  just really slow and dim during the day
AntiRiceCRX
« Reply #16 on: May 31, 2006, 08:44:30 AM »
yea i got it to work,my battery is like shot, i dont have my receipt but i bought it last year and its got a crack in it and when i try to charge it, it boils out of the crack????? but yea when i rev it up the blinkers will start to blink VERY BRIGHT compared to my old relay.
dminner
« Reply #17 on: May 08, 2007, 10:36:14 AM »
Guys, you keep mentioning 2 prong relays, but I am confused because all the wiring digrams form my bike (a cb550) show three wires, a gray, black, and green wire going to the relay.  I am in the process of rewiring my bike and bought a new electrical panel off ebay.  It actually came with a 2 prong relay, with the green wire just hanging loose, is this acceptable?  I just figured it had the wrong relay.
Offline medic09
« Reply #18 on: May 08, 2007, 04:43:13 PM »
The electrolyte fluid in your battery is prone to a mild boil in any case.  Just listen closely sometime when it is on the charger.  A cracked battery should be replaced IMMEDIATELY in my humble opinion.
BTW, I use the cheapy auto parts flasher relay (DOT 552?) on my K8 with no problems.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline Gordon
  • 750K1, 550K2
« Reply #19 on: May 08, 2007, 07:08:05 PM »
I don't think he's listening.  He posted that almost a year ago and hasn't been around since.
Offline medic09
« Reply #20 on: May 08, 2007, 09:01:47 PM »
Okay, now I feel stupid!  ::)
How did this get revived?   ???
Mordechai
'78 CB750K
Santa Fe, NM
Offline mikedialect
  • cbjunky
    • Mike's Metric Vintage Honda
« Reply #21 on: May 08, 2007, 09:03:30 PM »
even though this seems to be a dead thread...
this one worked great for me!
SOHC4 Member#44153
www.mikesmetric.com | www.mikedialect.com
Offline puppytrax
« Reply #22 on: May 09, 2007, 03:43:36 AM »
Is that the 2-prong electronic flasher?? I need one on my bike, I think...my signals are very slow...and my inspection is due within 10 days...   :P
(This thread was revived because the snow has finally melted).  ;D
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
« Reply #23 on: May 09, 2007, 08:00:29 AM »
To all, its ok to use a 2 prong relay and leave the green dangling!
The green is the ground for the UK type flasher from Honda that costs £40 ($80) YEP THATS RIGHT
Offline ic455
  • 750 K6
    • My Gallery
« Reply #24 on: May 10, 2007, 04:43:39 PM »
my diagram (750 K6) shows that green wire near the turn signal blinker, but not connected to anything.  I believe it's a spare ground.
