Author Topic: No 12v power to ignition.  (Read 1897 times)
Offline 75 super sport
« on: February 28, 2012, 10:21:45 AM »
I have no 12v power going to anything. No lights work, or horn. What is the correct way to test for 12v going to the ignition? With a multi meter I put the positive on the red wire coming to ignition, then the negative grounded to the frame. Shows no voltage. I have 12v going to the rectifier( I believe that is what it is). New to the cb750 and trying to get the bike running that i just purchased. Any tips to atleast get power to the ignition? Thanks in advance for the help!
« Last Edit: February 28, 2012, 10:27:00 AM by 75 super sport »
"Smoke em if ya got em"
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
Re: No 12v power to ignition.
« Reply #1 on: February 28, 2012, 10:40:04 AM »
The red lead to the ignition is fused (15 A).  Is the fuse good?  Do you have the correct wiring diagram for your bike.  I have a '76 f1 (same wiring).
« Last Edit: February 28, 2012, 10:43:24 AM by ChuckG750f1 »
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline Kurt V
« Reply #2 on: February 28, 2012, 10:43:16 AM »
Kickstand kill switch stuck?
1976 Honda CB400F-original survivor
1976 BMW R75/6
1993 Ducati 900SS
« Reply #3 on: February 28, 2012, 10:47:49 AM »
I am not familiar with kickstand kill switch? Where is this located?
« Reply #4 on: February 28, 2012, 10:57:57 AM »
Ok found that fuse, it was bad. Put one in, lights turned on and had power to ignition. There was a solenoid looking thing with three prongs, 1 black, brown, and green wire it says flasher on the side of it? Well that started clicking like a blinker would, then it stopped and my lights stopped with it. The fuse is still fine, what is the flasher? Thanks again for the help!
Offline ChuckG750f1
« Reply #5 on: February 28, 2012, 11:25:39 AM »
OK, that is the turn signal relay.  It should not be active if the turn signal switch is in the middle position.  If the switch was in the middle position when it was clicking then you may have broken/shorted wires in the left side control (high/lo beam, horn and directionals).  I can e-mail you the wiring diagram if you want.  -Chuck
- John Wayne
1976 CB750 f1
« Reply #6 on: February 28, 2012, 11:34:18 AM »
please do, i think that might help. there were two wires connected to the relay, then a green wire which i assumed was ground which was hanging by the third terminal and i hooked that up. was that not supposed to be plugged in? thanks again
Offline ChuckG750f1
« Reply #7 on: February 28, 2012, 11:44:39 AM »
Green wire should not be connected.  Give me your e-mail address.  -Chuck
- John Wayne
1976 CB750 f1
« Reply #8 on: February 28, 2012, 11:54:26 AM »
powellml67@yahoo.com thanks again!
Offline ChuckG750f1
« Reply #9 on: February 28, 2012, 12:02:51 PM »
Sent.
- John Wayne
1976 CB750 f1
« Reply #10 on: February 28, 2012, 04:26:34 PM »
It's located on other bikes, not our's.
Extra green wire with a shielded female connector is a spare. I don't think anyone has determined it's future purported use so just ignore it.
« Last Edit: February 28, 2012, 04:29:12 PM by Jerry Rxman Griffin »
« Reply #11 on: February 28, 2012, 06:29:05 PM »
There was a thread on that, the extra green wire was the ground for your CB radio!
« Reply #12 on: February 28, 2012, 08:34:20 PM »
Thanks alot guys. I unplugged the green wire and gave it a minute. Took the fuse out and put it back in and eureka! I have power. My low beam head light and horn dont work, Any suggestions?
« Reply #13 on: February 28, 2012, 08:46:46 PM »
Easiest way to check your horn, run two wires directly to the horn from the battery,
Offline magconpres
« Reply #14 on: February 28, 2012, 08:47:06 PM »
Possibly a bad switch.
could be the wiring as well.
Low beam should be the white wire from the switch.  The dark blue is the high beam.   You can check them for power in the connections under the tank0.
The horn is grounded by the switch.  Check for power on the black wire at the horn.  If you have power, you can test the horn by grounding the green wire to the frame.  If it goes BEEP, then it's good and the problem is the switch.
1975 CB400F, stock,  on the road
1975 CB400F, ran when I parked it. Cafe Racer bound
1986 TLR200 commuter and trail bike when with the kids...90MPG!
1986 TLR200, Vintage Trials build up coming
1986 TLR200, Not sure what to do with this one...Vintage Trials Super Moto?
2004 GasGas 300EC...my enduro racer
2004 Sherco 290...Trials bike
2004 CRF70... Son's ride
2006 PW50 ... Daughter's ride
1982 XL500R (04 XR250 front end)...my DS bike.
Offline Spanner 1
« Reply #15 on: February 28, 2012, 09:55:43 PM »
Need to get down-and-dirty with every electrical connection on your bike , Start at the battery. Don't stop until all the connectors are completly shiny and tight fitting in their connector mates. Do the big white 6 way alternator plug and the big rectifier plug. Make the male 'spades' bright and a tight fit in their opposites.
Shine the fuse clips and be sure they get a firm grip on each end of the fuse. Look on the back of the fuse block for any burning/melting. These things will stop your bike from running when you are far from home, much more prevalent than some mechanical failure.
You will cure any and all your electrical problems now and in the future ( on the road ) if you do this now.
I know your dying to get your bike running ASAP, but fix the wiring once now and strike it off the list  ;)
Offline ChuckG750f1
« Reply #16 on: February 29, 2012, 05:48:54 AM »
I think when you finally open the left handlebar control housing you are going to find shorted connections.  It's an easy place to start and it is implicated in every symptom you've had!  I won't mention it again.
- John Wayne
1976 CB750 f1
Offline Xnavylfr
« Reply #17 on: February 29, 2012, 06:21:40 AM »
Try this diagram, all the 750s were very similar  in the wiring. This diagram also shows you the color of the wires as they should be.
http://www.hondachopper.com/garage/cb750k1_wiring_diagram/cb750k1_wiring_diagram.html
http://www.satanicmechanic.org/wiringcodes.shtml
Xnavylfr(CHUCK)
Offline ChuckG750f1
« Reply #18 on: February 29, 2012, 08:35:41 AM »
I sent him the correct CB750 f1 color diagram yesterday.  I've used it alot for my bike and have not found anything wrong with it yet.
- John Wayne
1976 CB750 f1
« Reply #19 on: February 29, 2012, 09:44:32 AM »
Chuck the wiring diagram helped out a lot! Thank you and everyone else for the help. This forum is great!
