Author Topic: priority in the build - porting or cam first  (Read 2631 times)
Offline TheJawsOfDeath
« on: February 28, 2012, 06:01:43 PM »
Excuse me if this has been covered, but I couldn't really find an answer after searching for a bit. I'm at a crossroads on the rebuild of my 750 K8's engine.  I can afford either a high perf cam, or having the head ported by mike on the boards here, not both.  The porting job is going to be about twice as much as a cam.  Engine is going to be otherwise rebuilt with stock bore.  My build is budget minded, i.e. I'd be using a cam that will work with stock springs.  What's the best bang for my buck for the money?
1978 CB750 K
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
Re: priority in the build - porting or cam first
« Reply #1 on: February 28, 2012, 06:28:05 PM »
Hey Jaws ; This is just my opinion but I would say do the port first. Granted the cam is cheaper and will put (probably more) performance in your motor Now. But I look at it in the long run, giving the motor the ability to breath will help now and when you cam it. And besides if you get the port job now then with just a little coin you can drop in a cam! Like I said this is just mt opinion  ;D . I'm sure you'll get more opinions, just give it a little time .   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
Offline kpier883
  • is quite the
« Reply #2 on: February 28, 2012, 08:06:18 PM »
There is a thread around somewhere in which a stok bike is ported without other changes.  Results were good.  I'll try to find it.
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
« Reply #3 on: February 28, 2012, 08:13:28 PM »
Port it first, porting these heads give the single biggest gain in performance than any other mod. Check the forum for a cheap cam, should be one here somewhere.... ;)
Offline kpier883
  • is quite the
« Reply #4 on: February 28, 2012, 08:15:58 PM »
Found it:
http://forums.sohc4.net/index.php?topic=40311.msg415347#msg415347
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
« Reply #5 on: February 28, 2012, 08:19:05 PM »
THAT'S the post! Thanks.  I just couldn't find it for some reason.
1978 CB750 K
« Reply #6 on: February 28, 2012, 08:29:38 PM »
...hmm...seems I'm getting ported first.
1978 CB750 K
Offline kpier883
  • is quite the
« Reply #7 on: February 28, 2012, 08:57:51 PM »
I think that is a good choice.  I hope to do the same some day.  A guy can dream, right?
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline BLUE71TURBO
« Reply #8 on: February 28, 2012, 10:51:52 PM »
Since your going to have the head off to do port work and a valve job you should really install new better valve springs not that much more $$ .    ;)
Offline dragracer
  • CB750F Dragbike
« Reply #9 on: February 29, 2012, 09:22:55 AM »
What he said!!!
Offline Bill/BentON Racing
    • BentON Racing
« Reply #10 on: February 29, 2012, 06:23:40 PM »
+1.Valve springs cheap insurance...don't risk that head! Bill
BentON Racing Website
BentON Racing Facebook
« Reply #11 on: February 29, 2012, 06:41:39 PM »
Valve springs are good insurance against valve float when you miss that 1 - 2 power shift as I did. Total destruction ensued.
Now with that being said the 78 K already uses the stronger springs found in the 77 & 78 F. I'm sure Mike will fit you with even stronger KPM springs while he's at it.
