Author Topic: Rocker Shaft Trouble  (Read 18848 times)
Re: Not Happy Hondaman
« Reply #25 on: March 02, 2012, 12:30:09 PM »
Subscribed.
« Reply #26 on: March 02, 2012, 12:52:00 PM »
The oil feed o ring recess next to #2 looks much deeper than the one next to #3 (looking at the pics in the original modification post). The deck has certainly be milled. ;D I wonder how the cam chain tensioner was doing? You reach a point where you have to shim the cam towers to make up for lost material. I don't know....I try not to get involved in these threads because it is all about speculation etc.
Offline markb
  • When I finish my current project I might be a
« Reply #27 on: March 02, 2012, 12:54:46 PM »
I would probably be a bit more apprehensive before publicly denouncing hondaman  ;)
+1
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline heffay
« Reply #28 on: March 02, 2012, 12:55:23 PM »
Censored
« Last Edit: March 06, 2012, 06:25:38 AM by heffay »
« Reply #29 on: March 02, 2012, 12:59:56 PM »
im more scared of the avatar.
Offline wrenchmuch
Not Happy Hondaman
« Reply #30 on: March 02, 2012, 01:13:32 PM »
I wonder if the the hold down bolts used were threaded from the bolt head down or unthreaded until the last centimeter and a half like the stock ones. Looks like threads might have been eating the shaft. Wheres the op.
I am here: http://tapatalk.com/map.php?y1iagy
CB750K1
CB750K4
Offline cheapride
  • Work Hard Play Hard
« Reply #31 on: March 02, 2012, 01:45:15 PM »
did it sound like this?
Senile Talking Cat! (The Original)
That is some funny stuff there....
1978 cb750f Supersport
« Reply #32 on: March 02, 2012, 01:59:08 PM »
Wheres the op.
Probably too embarrassed at blaming his own (unstated) build mistake on someone else publicly.
...But, I'm just guessing. ::)
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #33 on: March 02, 2012, 02:05:48 PM »
I have tons more popcorn, where is OP?  8)
Offline cbr954
« Reply #34 on: March 02, 2012, 02:10:00 PM »
I am also running without the 5mm bolts and I have no problems.  We need photos of the other involved parts to see the rest of the story(rocker arm bores, cam tower bores, the bolt that "chewed" up the shaft, etc.).  Wondering if the bores that the shaft ride in are either too tight or extremely worn and out of alignment so the shaft is bouncing around in cam tower.  Plus that shaft is a lot harder material than that little bolt.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
« Reply #35 on: March 02, 2012, 02:18:49 PM »
tHE WAY i'M SEEING IT, the wasp waist is where the damage is. The bolt that goes there is a few inches long, 6mm and hardened. So its not a little bolt. Still I can't envision the circumstance that would cause that damage. Other than using a 1/4-28 bolt thats threaded all the way up as one alluded. Even at that the rocker pin simply doesn't move with any force, it justs drifts around. Uness of course its been seized to a rocker arm which is then rocking the pin back and forth causing a sawing motion.
But too much spec. I'm out. Good wishes for a resolution. Don't wish bad outcomes on anyone.
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #36 on: March 02, 2012, 02:29:29 PM »
I got here late but I still gotta ask, "Why are you blaming Hondaman?"  Because you think leaving out the bolts ruined your engine? :(
Offline Mooshie
« Reply #37 on: March 02, 2012, 02:46:53 PM »
Who the heck is 7 post count groover??
I want to put that on a T-shirt. ;)
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline gecko672
« Reply #38 on: March 02, 2012, 02:48:06 PM »
The plot thickens..... Im in...
CB750 1971 K1
Offline Bailgang
  • Scott
  • Indiana
« Reply #39 on: March 02, 2012, 03:48:48 PM »
Yep I was wondering the same thing.  ???
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Damfino
« Reply #40 on: March 02, 2012, 03:56:33 PM »
He's in Australia. Probably just sitting down to his bowl of Wheaties...
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline heffay
« Reply #41 on: March 02, 2012, 04:00:15 PM »
having trouble finding 4 cats fighting, much less fornicating
sound like this at all?...
Real Cat Fight ( Turn Audio ON)
Offline Groover
  • Groover
« Reply #42 on: March 02, 2012, 07:42:21 PM »
First, thanks for everybody's interest.I am thankful for all the suggestions and speculation as to what may have caused this rocker shaft damage.
The rocker shaft is the only component damaged.Please note it is not broken in two.Where the shiny bits are are where the shaft has oscillated against the 6mm centre bolt. That bolt is a high tensile plain shaft of correct length as per parts book (i.e. not threaded all along its length) That bolt has only the slightest scuff mark on it.
Both sides of the waisting are gouged out on the rocker shaft. To me this says the shaft was free to float, at least in the end-to-end direction. Since the shaft was floating their must have been some lubrication.
As to my being abusive of Hondaman , I was not, read the original post. I was pissed off at the situation however as would any one who had to remove and disassemble their engine again.
HM states on page II-6 "At a minimum, consider removing the 5mm lockdown bolts during your reassembly (unless worn, which mine weren't)." That is unambiguous.
I still maintain the lack of 5mm bolts allowed this damage to occur.
Had they been there, this damage could not have occurred.
Groover.
Offline kpier883
  • is quite the
« Reply #43 on: March 02, 2012, 07:49:16 PM »
How long did it run that way?
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
« Reply #44 on: March 02, 2012, 08:09:58 PM »
I believe the point is they came from the factory that way, thousands of them. What made yours different? Maybe more pics would help. I'd hate for you to put it back together and still have some sort of problem. Maybe we can all learn something.
Offline mick7504
« Reply #45 on: March 02, 2012, 08:28:18 PM »
Let me know if you can't find a replacement shaft mate.
Hopefully we can get to bottom of this.
If I was you
I'd be worried about me.
Offline cbr954
« Reply #46 on: March 02, 2012, 08:38:11 PM »
Maybe its just the way the picture looks but the shaft looks dark like it got hot at some point.  It also looks like it has some wear on it where it rides in the cam tower.  With this much wear on the shaft its hard to believe the bolt only has a slight "scuff mark" on it, I would think the bolt would look as bad or worse than the shaft.
« Reply #47 on: March 02, 2012, 09:27:14 PM »
Show off. ;)
Offline jaguar
« Reply #48 on: March 02, 2012, 09:30:09 PM »
I still cant see how the missing bolt would cause the damage?
How do you know that your motor was perfect in every way other then the bolts?
« Reply #49 on: March 02, 2012, 09:43:20 PM »
was the case split for your rebuild,you said you had a lot of metal in the oil etc,whats come off the shaft wouldnt amount to much for want of a better description,its an ex broken camshaft engine,maybe what you found was also from its past incarnation if the case wasnt split?you said the bolt wasnt worn much,im guessing its been binding with the rocker,your getting oil up top?you primed and had oil pressure before you let it fire?there should be two fifths of #$%*-all side ways pressure on rocker shafts,if youve mixed and matched rockers and cams you can get a bad set up.
« Last Edit: March 02, 2012, 09:45:18 PM by dave500 »
