Author Topic: Installed the carpy 550 exhaust.  (Read 6431 times)
Offline singedebile
Re: Installed the carpy 550 exhaust.
« Reply #25 on: March 05, 2012, 10:27:16 AM »
it mentions on carpy's site that you should rejet the mains with this exhaust... is this only the case if you previously had a 4-4 and not the already re-jetted supersport?   ...in other words did you rejet? a
I was told from one person where I live to see how it runs...he said it might just run fine..so that's why I put the carbs back in...carpy told me to bump up the mains to 120 from my 110. I think ill need to pull the carbs out again..not sure what to do. Well if I do that I might as well buy new boots for them cause I know they won't be in good shape after one more pulling around
Sent from my PC36100 using Tapatalk
there are a bunch of threads for conditioning the boots (soaking them in different things) assuming they dont have any holes after you remove them.
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Offline messeduptriple
« Reply #26 on: March 05, 2012, 11:21:24 AM »
I got my gaskets for the exhaust... Will these just go into the headers snugg? Or is there a technique to get them to settle in??
* gotta go to work now so haven't been able to look inside the headers.
Offline EricHa
« Reply #27 on: March 05, 2012, 12:37:49 PM »
I'm a noob to the 550, but on my other bikes I use a tiny piece of Scotch tape to hold them in if necessary. Either stick it, or fold it into a shim to wedge the gasket in place.
1975 Honda CB550K1
1976 Honda CB750K6
1977 Kawasaki KZ900A5
Offline Scott S
« Reply #28 on: March 05, 2012, 04:53:09 PM »
 They don't go inside the headers. Put them in the head/exhaust ports. Make sure the old ones are removed. They get crushed flat and covered in carbon and are easy to overlook.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #29 on: March 05, 2012, 05:41:00 PM »
Your avatar is nuts dude.
Offline singedebile
« Reply #30 on: March 05, 2012, 07:55:38 PM »
I was going to try to find its source but the reverse image lookup site i use has a minimum size...  but yeah pretty awsome
Offline matt mattison
« Reply #31 on: March 06, 2012, 02:53:30 AM »
I squeeze them in my hand a little to get them slightly oval so they stick in the ports. If you really gorilla grip these washers, it could fold on you,don't ask me how I know. Then just stick them in the ports.
1975 CB550F
2011 MV Agusta Brutale 1090RR
Offline EricHa
« Reply #32 on: March 06, 2012, 06:05:26 AM »
That is the legendary Boris Murray at Bowling Green circa 1971. His twin engine, nitro powered, high gear only Triumph was the king at that time.
1975 Honda CB550K1
1976 Honda CB750K6
« Reply #33 on: March 06, 2012, 06:22:55 AM »
Little dab of permatex  silicone etc will hold them in the head also.   ;)
Re: Re: Installed the carpy 550 exhaust.
« Reply #34 on: March 06, 2012, 07:04:16 AM »
Inside. You'll have to use a "pick" tool to get the old ones out.
thanks for the headsup to get the gaskets..I would have never known. Got them in last nite, also took out the carbs again so I can install the 120 jets. The removal of the carbs was so much easier this time.
« Reply #35 on: March 10, 2012, 08:22:37 PM »
So I bumped up to the 120 main jets....should I stay at the 38 pilot jet?? Or the idol is that what it is?? Just want to get some info on what some think I should have for jets with this exhaust.
