Author Topic: *Dumbing it down? vote!  (Read 2245 times)
Offline B.O.X.N.I.F.E.
  • The Stumped
« on: March 05, 2012, 12:20:57 AM »
I'm considering dropping my 550 down to 500 so I don't have to race in the 650 class out at Bonneville.
Are there tables anywhere online that calculate displacement & compression after decking & .25/.5/.75/1mm bores? I've tried a search but haven't found anything straightforward to use.
« Last Edit: March 05, 2012, 05:30:21 PM by B.O.X.N.I.F.E. »
1974 CB550
Forever West
Offline cavebear
Re: How to calculate CC's after overbore
« Reply #1 on: March 05, 2012, 12:25:53 AM »
Displacement is pi r squared x bore x 4
1975 MotoMartin 836cc
1976 Rickman 1150cc Turbo
1977 Seeley 890cc + 1/4 stroke
3 parts bikes,1970K0 to 1978ss
Get paid to do it,it's work; pay to do it,it's a hobby
  • The Stumped
« Reply #2 on: March 05, 2012, 12:40:11 AM »
Does that take stroke into account??
This handy calculator: http://www.ajdesigner.com/fl_engine_displacement/engine_displacement.php
gives me 502 with a .25 overbore, the smallest I can readily find pistons in. I guess my question should have been more focused on results of milling the head; can I lose those 2 cc's without raising the compression ratio too high and maintaining piston/valve clearance? Are there formula's for this?
1974 CB550
Forever West
« Reply #3 on: March 05, 2012, 12:43:33 AM »
pi r squared x stroke,,then times four,when you rebore oversize your static compression goes up.
« Last Edit: March 05, 2012, 12:46:36 AM by dave500 »
Offline cavebear
« Reply #4 on: March 05, 2012, 12:54:26 AM »
I made a mistake. It is stroke instead of bore
  • The Stumped
« Reply #5 on: March 05, 2012, 09:31:55 AM »
Anyone know what the formula is for calculating displaement after decking?
1974 CB550
Forever West
Offline KJ790
« Reply #6 on: March 05, 2012, 09:39:51 AM »
The displacement of the engine doesn't change from decking the head. Displacement is strictly a function of stroke and bore. Decking the head will increase your compression ratio by decreasing your combustion chamber volume, but the amount that it decreases depends completely on the shape of your combustion chamber to begin with, so there is no universal formula for that.
  • The Stumped
« Reply #7 on: March 05, 2012, 11:45:34 AM »
I didn't realize that.
Well crapo. I can get a set of std. pistons, but what are the chances someone out there is still making std. bore sleeves....
1974 CB550
Forever West
« Reply #8 on: March 05, 2012, 11:53:00 AM »
You're in luck, go to LASLEEVE.com
  • The Stumped
« Reply #9 on: March 05, 2012, 12:00:22 PM »
90$ per sleeve... wow
1974 CB550
Forever West
« Reply #10 on: March 05, 2012, 12:17:23 PM »
To expand on what KJ said, displacement is just that. The amount displaced by the stroke of the piston. All else is a constant, and doesn't figure in.
My favorite calculator:
http://www.nightrider.com/biketech/calc_displacement.htm
  • The Stumped
Re: *Dumbing it down? vote!
« Reply #11 on: March 05, 2012, 05:30:40 PM »
Saving that, thank you!
1974 CB550
Forever West
  • The Stumped
« Reply #12 on: March 05, 2012, 05:32:40 PM »
Hmmm... so if I do a .25 over on a 500 block that puts me at 502. That won't cut cheese on the salt in the 500 class.
Would you:
A: Find a low mile 500 block, hone up, run NOS std. 500 pistons
B: Bore up the 550 to 590ish and run with the 650's
1974 CB550
Forever West
Offline heffay
« Reply #13 on: March 05, 2012, 05:38:08 PM »
Just because you're in the 650 class doesn't mean everyone is runnin' 650s.  They're all runnin hopped up 550s like you. ;)
« Reply #14 on: March 05, 2012, 06:01:12 PM »
Look for a 500 block and pistons; they don't have to be low mileage, as long as they are within wear limits. (Race motors are built "loose", anyway. ;))
  • The Stumped
« Reply #15 on: March 05, 2012, 06:27:29 PM »
I gotta say I'm leaning towards the 500. Cost is a contributing factor; maybe $200 all in for the 500. A big 550 after machining would be $500 - 800. Thats money I could put into the head, which is probably where the most bang for my buck is anyways.
1974 CB550
Forever West
« Reply #16 on: March 05, 2012, 06:49:04 PM »
Even at 590cc, the 650s have a 60cc (5-6 HP) advantage....
Offline geminimotors
« Reply #17 on: March 05, 2012, 06:53:45 PM »
If I were in you shoes, I'd run the biggest 500 pistons, cylinders, etc that the class allows and use the 550 bottom end, and work all of the magic I could beg, borrow, or steal on the head, intake, and carbs. It's been said by NHRA B-stock engine builders- "If you aren't winning, you aren't cheating"
« Reply #18 on: March 05, 2012, 10:08:53 PM »
 Get good used 500 bores like Scottly said, get new rings..
 Dont go streamlined there is a guy running 205 +.. Canadian team.
 I would not worry so much about how fast you will go as getting there, and figuring out how the game plays. You can run in RWYB for cheap, and get trhe feel of  the salt.. then you will be hooked !!
 RWYB=run what you brung... are you thinking Speedweek or Bub Bike week?..Bub is earlier this year..
  • The Stumped
« Reply #19 on: March 06, 2012, 03:40:17 AM »
I doubt I'd go out for Speedweek. BUB is already a week earlier, and Speedweek is earlier than that. I have a little list, and if I stick to it, I should have her put together with about 3 weeks leftover for tuning. We'll see...
It'll be RWYB for me this year. Running official seems like a differect ball game. And if it were Speedweek I doubt I'd ever pass SCTA tech anyways.
1974 CB550
Forever West
« Reply #20 on: March 06, 2012, 09:03:30 AM »
 Good choice, Speedweek is very busy.. and Bub is very bike friendly.. no matter how fast you go you will have fun there.. hope I make it to BUB this year..
