Author Topic: 18" front wheel on CB550?  (Read 1820 times)
Offline Mighty550
  • 76 CB550F
« on: March 05, 2012, 08:59:14 AM »
I just got a 76 CB550, and I want to go to an 18" front wheel.  Would the front wheel of a CB350 be a direct swap?  Any other wheels that may be a direct swap?
Thanks!
Offline greenjeans
  • 1972 CB750K2
Re: 18" front wheel on CB550?
« Reply #1 on: March 05, 2012, 09:08:28 AM »
Not 100% sure off the top of my head, but you could most likely run that wheel off the 350 and use the axle from your 550.   I believe that the triples on the 350 are a bit narrower than the 550.   You might have to have a spacer made but that's probably about it.   You could use whatever spacer you have left over from the swap and cut/machine it to the correct width.
That 350 have a drum or disc hub ?
Offline Mighty550
  • 76 CB550F
« Reply #2 on: March 05, 2012, 10:01:14 AM »
The 350 wheel im looking at has a disk.
Offline Mighty550
  • 76 CB550F
« Reply #3 on: March 06, 2012, 04:13:14 AM »
Can anyone else confirm this?
Offline Gman
« Reply #4 on: March 06, 2012, 06:51:19 PM »
Out of curiosity, are you swapping for a particular look for your build, or is there some performance reason?
G
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
Offline fastbroshi
  • Puppet
« Reply #5 on: March 06, 2012, 09:41:10 PM »
So you're looking to swap the whole front wheel with its hub and all?  I think you'd have to do it this way as the 350 hub is 36-spoke if memory serves.
Just call me Timmaaaaay!!!
Offline Mighty550
  • 76 CB550F
« Reply #6 on: March 07, 2012, 04:07:52 AM »
I want to do this because I like the look of both the front wheel and rear wheel being the same size.  I am thinking of swapping the entire front wheel assembly over, I have to image that would be the easiest way to do it.
