Author Topic: cleaning up engine  (Read 1464 times)
Offline slowjo
cleaning up engine
« on: March 06, 2012, 02:20:26 PM »
So I removed my engine and now its time to clean it. What would you do and how would you do it? I like to keep it simple and work smarter not harder. So of you had a choice to use good old fashion elbow grease or soda blast what would it be?
Re: cleaning up engine
« Reply #1 on: March 06, 2012, 03:40:19 PM »
Currently doing the same...I dunno I think I might be working harder...it's real dirty...
Online CycleRanger
  • No comment about being an
« Reply #2 on: March 06, 2012, 03:48:37 PM »
My engine wasn't really filthy but it was dirty.
I used engine degreaser, simple green, brass brushes, nylon brushes and lots of rags.
I had the engine mounted on a stand so it was easy to rotate.
It should go without saying that you need to seal up all the holes before you begin.
Offline Lostboy Steve
cleaning up engine
« Reply #3 on: March 06, 2012, 03:48:41 PM »
Power wash and purple power then a nice coat of silver grill and oven paint or your choice of coating...
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline andrewk
  • doin' it.
« Reply #4 on: March 06, 2012, 03:54:34 PM »
I use a lot of the Advance Auto brand "heavy duty degreaser"  Smells about like diesel fuel, but it works pretty good for cleaning up engines.  If you can hook up a hot water hose with a high pressure nozzle, that will also help things along.
I've also got some car wash brushes I picked up at some box store- one's a stiff bristle that's good for scrubbing down the fins.
I recommend the elbow grease method- even if you were to blast it afterward, you would want all the grime you can get off of it.
Alternate method would be to take it to your local car wash and go to town on it.  That's a pretty cheap way to get a hot water pressure washer.
Offline slowjo
« Reply #5 on: March 06, 2012, 04:03:33 PM »
I have access to both pressure washer and soda/sand blaster. The engine is mounted onto a stand. I just used a can of gunk engine degreaser and some water on it after work just to loosen things up a bit.
« Reply #6 on: March 06, 2012, 04:27:49 PM »
Hey Sean,Can I have those custom 'rubber' exhaust spigot covers when your done. I will recycle-reuse them and lessen my carbon footprint. They are 'dirty'-----   :o
« Reply #7 on: March 06, 2012, 04:40:37 PM »
sure Eric, as long as you don't pay for them with your health insurance...
