Author Topic: How do you keep from melting your clutch cable?!? CB750F  (Read 1668 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: March 06, 2012, 03:57:25 PM »
Ugh... BRAND NEW Motion Pro -3" clutch cable just melted against my pipes. Again. The cable is the perfect length for the "euro" bars that I have on the bike, being pulled fully tight when turned all the way left. When you turn all the way right though - and maybe not even all the way - it pushes out against the pipes. I've tried zip-tying it tight to the frame but that makes it bunch up between the frame and the neck. Most recently I used some of those velcro cable wraps (for guitar cables and whatnot) and loosely had it strapped to the frame; but just now while sitting in traffic the heat from the pipes melted the velcro and now I have another melted clutch cable. Any suggestions?!? I'm tired of replacing these!
Offline LesterPiglet
  • 1977 CB550F2
Re: How do you keep from melting your clutch cable?!? CB750F
« Reply #1 on: March 06, 2012, 04:01:05 PM »
Is it routed properly? I don't know about the 750 but my 550 cable goes over the top of the engine and between the carbs.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: March 06, 2012, 04:11:33 PM »
750 goes thru the top clamp between speedo/tach and down left frame.
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
« Reply #3 on: March 06, 2012, 06:13:04 PM »
Zip tie it tight against the frame tube, so it won't flop over and touch the pipes, worked for me!
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline Shane72
« Reply #4 on: March 06, 2012, 06:16:13 PM »
My only suggestion is to get the next cable an inch or two longer.
It won't need to move as much with the bars then, allowing your zip ties to be a bit more effective at holding it in place.
Good luck,
Shane
I mount and balance MC tires--while-you-wait service by appointment.  Send me a PM.
« Reply #5 on: March 06, 2012, 06:53:36 PM »
I use the spring metal clamp from an early Z900/KZ1000 part # 92037092
« Reply #6 on: March 06, 2012, 07:43:04 PM »
I used to have my cable zip-tied to the frame tube, but it put it into a slight bind. I made a guide for the cable, fastened to the motor mount. I'll try to post a pic tomorrow...
« Reply #7 on: March 06, 2012, 07:50:04 PM »
I had to run mine in front of the instruments, to let it loop out front rather than pushing the slack into the pipes down low. It rubbed a mark on the HLight shell, but it didn't melt.
bollingball
« Reply #8 on: March 07, 2012, 05:54:31 AM »
I have mine routed the same way and it is zip tied to the bracket at the horn that the tach cable goes through and the triangle motor mount down lower doesn't touch the pipes
                                                Ken
Offline KB02
« Reply #9 on: March 07, 2012, 04:05:33 PM »
+1
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #10 on: March 07, 2012, 04:33:00 PM »
I use one of the Honda aluminum straps with the plastic covering from the wiring harness under the tank and install it loosely just above the front engine mount.  This allows it to flex and move but not contact the pipe.
« Reply #11 on: March 07, 2012, 04:48:33 PM »
Here are a couple of pics of the guide I made; cut it from some thin aluminum, and slipped some heat-shrink tubing over it.
