Author Topic: RE: $50 solid state Regulator / Rectifier will it work  (Read 2232 times)
Offline chewbacca5000
  • I polish covers!
« on: March 11, 2012, 09:11:50 AM »
Quick question since this Regulator / Rectifier is for an 80's honda and has all the correct colors will it work for a CB750?
http://www.ebay.com/itm/180839013783?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
It's either this one, or the one from Carpy site.
Thanks!
Offline CycleRanger
  • No comment about being an
Re: RE: $50 solid state Regulator / Rectifier will it work
« Reply #1 on: March 11, 2012, 09:19:13 AM »
Thanks!
Before you do that, read this thread!  :)
http://forums.sohc4.net/index.php?topic=12465.0
  • I polish covers!
« Reply #2 on: March 11, 2012, 11:42:37 AM »
Thanks!  I have glanced at Pinheads mod, but am really looking for more of a plug and play solution as my play / experiment budget is used up on my HEI project for my CB750.
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
« Reply #3 on: March 11, 2012, 01:52:53 PM »
As long as the internal diodes are the same (check the schematic), it will work.
-David
« Reply #4 on: March 11, 2012, 03:21:53 PM »
The rectifier section will work fine.  Not so sure about the regulator section is plug and play.
The CB750's field coil grounds one side of the field coil and powers the other.
The DOHC4's regulator provides both power and return to the rotor.
Given the data I found below, I'd be dubious of success claims and suspect the regulator may be damaged unless mods to the SOHC4 alternator field coil is also made.
Perhaps there is a credible reason why the CB750 SOHC4 isn't on the advertiser's fitment list?
  • I polish covers!
« Reply #5 on: March 11, 2012, 06:33:23 PM »
Much Thanks TwoTired for helping me dodge this bullet.  Do you have an information / objective opinion on Carpys setup?  That looks like it is specifically made for the SOHC cb750?
Thanks Again!
Offline CycleRanger
  • I polish covers!
« Reply #7 on: March 11, 2012, 07:22:17 PM »
Check this out.  http://www.oregonmotorcycleparts.com/Reg_rec_units.html
Thanks Cycle Ranger.  Looks like this guy has individual units or combo reg_rec.  The combo units are a little more pricy is there any benefit to the combo vs solo reg and solo rec?
Offline CycleRanger
« Reply #8 on: March 11, 2012, 07:53:37 PM »
imho, only for ease of install.
I used this regulator on my K5.
http://www.amazon.com/gp/product/B000C7YK4I/ref=oh_o00_s00_i00_details
I removed the plug and connected it right up.
Here's a picture of the reg and rec I put on my bike.  Total cost for both was under 50 bucks.
(Rectifier was $14 from ebay. $6 for plug kit from Oregon Motorcycle parts. Heat sink from PC.)
The full details are in that thread I posted.
