Logo merchandise is available at the SOHC/4 Shop
that leaf spring retains it,,,,,against the inside of the float bowl,,,you dont need to remove the carbs to change the jets,,with some dexterity you can wrangle the bowls off and back on in situ.
...........oh......... That seems like it would be kinda hard to do.
Quote from: dave500 on March 11, 2012, 12:37:49 AMthat leaf spring retains it,,,,,against the inside of the float bowl,,,you dont need to remove the carbs to change the jets,,with some dexterity you can wrangle the bowls off and back on in situ............oh......... That seems like it would be kinda hard to do. Sent from my PC36100 using Tapatalk
Quote...........oh......... That seems like it would be kinda hard to do. On the contrary, it's not difficult at all. I can do it blindfolded.
replace those little phillips(jis)with little allens,then make a short little key/ which fits them when on the bike.
