Tugboat, you need around 10mm ofset on the back.. you took a late style holder (would have worked with flat stock sprocket) that had 10mm offset, but cut 7mm off leaving 3mm offset. Now you added an offset sprocket PLUS 3mm. I assume the sprocket has a 10mm offset ( coorect me if wrong), that plus 3mmm makes 13... If your offset is7mm on the spreocket, you are in the right spot..
