Author Topic: Major electrical problem??  (Read 613 times)
Offline MikeJW
« on: March 15, 2012, 12:54:54 PM »
I have a 1972 750 which I bought almost 4 years ago. For the past 2 years, it hasn't given a problem of any kind. Tuesday, I was out riding and the bike suddenly quit. I found I had no electrical power at all. I knew the battery was fully charged, so I checked the fuse, which was fine. Turning the key to any position did  not give me any lights: neither headlight, taillight, turn signals nor dashboard idiot lights.....nothing. With no electrics, obviously, I couldn't even kick start. I checked for a loose wire in the headlight bucket and in the triangle under the battery and as I said, the fuse was not blown. I was in an exposed place, so I pushed into an empty parking lot. I noticed it was very hard to push even holding the clutch. The bike has always been very tricky getting into neutral. Once while I was pushing it, the power came back...I saw the idiot lights come on, but then it went away again. My question is- could this all be from a gone bad ignition switch?
I don't know if it is original or not, but I think it may be. Thanks, Mike
1972 CB750K2
Re: Major electrical problem??
« Reply #1 on: March 15, 2012, 01:06:47 PM »
It can be from a faulty ignition switch , or any fault in the connection between battery and ignition switch. It could also be a battery connection fault/intermittent, (even a loose battery cable).
You could just wiggle bits of bike wiring and watch for light/on off condition.  When you can make the light go on and off by wiggling just one bit, you found it!
« Reply #2 on: March 15, 2012, 01:37:17 PM »
as TT said, check wiring from ignition/controls/bars to headlight and under tank.
look for old, cracked wire insulation.
it gets stiff and exacerbate wire 'wear' if there are major bends/kinks.
I bet a slow side to side of your bars will flicker it on.
also check the pin connector block under you tank/seat.
Offline steam-powered man
  • Not the eggman, Not the walrus, I am the
  • Where are you going? I was going to make Espresso
« Reply #3 on: March 15, 2012, 01:59:23 PM »
+1
turn key to "on" position and wiggle wires behind iginition switch, then others.  at some point the idiot lights will come back.  good luck!
searching for a dr350se
