Author Topic: 78 cb750F Monkey Trainer "she is done!"  (Read 49210 times)
Offline kap384@telus.net
Re: 78 cb750F Monkey Trainer "Roller"
« Reply #50 on: May 26, 2012, 09:35:45 PM »
Dammit tweakin, I only just found the thread.  Been away from the board for too long.
Yours is still one of my all time favourite builds and I couldn't be more excited to see the finished product of this resto-mod.  As you know, I'm a resto guy.  Can't wait to see that CBX paint job on there  Looks awesome on that long 'F' tank.
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline tweakin
  • tear down
« Reply #51 on: May 27, 2012, 06:47:29 AM »
Thanks for checking in Kap.  If this build turns out half as nice as your sweet stocker I will be pleased.
Offline Roach Carver
« Reply #52 on: May 27, 2012, 07:35:47 AM »
Shiney. Marked.
« Reply #53 on: May 27, 2012, 09:38:09 AM »
Thanks tweakin
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1978 Honda XL100
1983 Honda CX650T
1995 Honda VFR750
2015 KTM 200 XC-W
1963 Suzuki T10
Offline tweakin
  • tear down
« Reply #54 on: May 28, 2012, 07:53:52 AM »
Finished up the brakes last night.  I added a nissin adjustable front to push the dial piston brakes.
I also got rid of the leaky rear master and upgraded to a new brembo unit with pressure unit for the brake light.
Today, I hope to get the oil pump rebuilt and button up all other loose ends so I can get started on the electrical tomorrow.
« Reply #55 on: May 28, 2012, 09:51:26 AM »
Second one is always quicker, huh!  ;D  You're getting good at this, what's next after this bike?
Offline tweakin
  • tear down
« Reply #56 on: May 28, 2012, 10:30:32 AM »
Jerry-  I have learned a ton from this site and trial and error.  This is my third cb and before that I built many Harley's which has also helped.  This time I was able to order most of the needed parts before I even had possession of the bike.  Next will probably be to ride and possibly a modern street bike in the near future, if I can talk the wife into it.   But you don't have that problem... ;)
Offline tweakin
  • tear down
« Reply #57 on: May 28, 2012, 10:16:58 PM »
I love long weekends... :D  I was able to do some more work on the 78f
engine is all buttoned up and the carbs are on with the exception of the clutch cover.  I did;t realize it was cracked so I am prepping another.
the gauges are rebuilt, waiting to put the instrument cluster on.
got the Corbin seat on, man this thing is like a couch compared to my 77's cafe seat.  Also mounted up my exhaust and ignition.
I think this bike is going to be a great, comfy, rider that should be a blast and still look close to stock.
Offline tweakin
  • tear down
« Reply #58 on: June 03, 2012, 02:10:35 PM »
Getting close.  Finishing up the wiring and then need to time, adjust valves, bleed brakes then complete.  I couldn't resist putting the tail and tank on to get an idea of how it will look.  Wish I would have rolled it outside so you can see how the paint pops in the sun.
I think the overall look will pay tribute to the stock F3 with some minor tweaks.  LED taillight with integrated turns is tucked up under the rear cowl, upgraded brakes and suspension.
I hope to do some shake down rides in the next couple weeks.
« Reply #59 on: June 03, 2012, 02:25:48 PM »
Looks great! That bottom stripe on the tank and cowl sure make up for the lack of trim. You're gonna have the nicest pair of F's anywhere.
Got my rear brake bled. Waiting for oil pressure to put the plugs in and fire mine. Close too!  ;D
« Reply #60 on: June 03, 2012, 03:59:20 PM »
That looks awesome Tweakin, the only thing i would change is the stock rear tail light, i would fit something into that rear cowling, i like where the stock cowling stops at the back of the rear tire, with the stock tail light it makes the back look too long, IMO of course  ;D ;)
Love the paint and seat....
« Reply #61 on: June 03, 2012, 05:00:36 PM »
That thing is gonna POP in the sunlight!  Awesome!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1978 Honda XL100
1983 Honda CX650T
1995 Honda VFR750
2015 KTM 200 XC-W
1963 Suzuki T10
Offline tweakin
  • tear down
« Reply #62 on: June 03, 2012, 05:23:18 PM »
Thanks fellas!!!
Retro, I agree about the stock taillight that is why it is gone on this bike, although I think it looks great on a stocker.. ;)
I added a LED stop, brake turn, tucked up in the cowl of the seat.  It is set know but I think I will fab up an aluminum bracket to move it back a bit.
I know there has been some banter about the Corbin not fitting well, but I think it fits great.  Just takes a bit to align it properly.
I also picked up a polished aluminum front fender for it, should look good.
« Last Edit: June 03, 2012, 05:26:14 PM by tweakin »
Offline brandEn
« Reply #63 on: June 03, 2012, 06:37:40 PM »
WOW, looks so cool!
« Reply #64 on: June 03, 2012, 07:49:41 PM »
I see a future BOTM!
Offline HonderCB
« Reply #65 on: June 03, 2012, 09:54:03 PM »
looking good tweak!
if you have the stock rear plastic fender that hangs down below the license plate you might try sticking it on there to see how it looks.  My F came without it, and i didnt think i wanted one anyway, but i bought one just to have in case.  After i put it on i thought it made the back of the bike look much better.  Its your bike so ultimately its up to you, but it might be worth a look anyway.  It might not look as good without the stock tail light anyway though.  Sweet bike nonetheless!
77' CB750F
81' CB650C - SOLD
« Reply #66 on: June 04, 2012, 12:51:46 AM »
Excellent... ;D   You've set the bar for builds on this forum mate..... ;)
Offline bikerbart
« Reply #67 on: June 04, 2012, 01:50:54 PM »
I hate you.What bars are those??M bars?Beautiful,friggin beautiful.
Offline nvr2old
« Reply #68 on: June 04, 2012, 02:22:27 PM »
Starting to look like a real bike again, tweakin.  I agree about maybe moving the tail light and plate back a bit in the cowl.  That's an awful lot of open space there.  From a 3/4 rear shot it looks like nothing's there.  The stock rear fender (shortened possibly..?) might even look good in there, too.  Whatever you decide, I'm confident the bike is gonna be killer..'cause it already is.. ;D
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline tweakin
  • tear down
« Reply #69 on: June 04, 2012, 05:51:11 PM »
Ha ha , thanks Bart...  The bars are Norman Hyde bars, I love them.  If you are interested in a set brandEn may have a set he would part with.
Offline tweakin
  • tear down
« Reply #70 on: June 04, 2012, 05:53:15 PM »
Yes,  Moving the taillight back about three inches is in the works but negative on the fender....  not for me.
This was just an initial mock up of the rear end.
Offline bikerbart
« Reply #71 on: June 05, 2012, 06:59:07 AM »
I have those bars on my bike.very cool.
Offline tweakin
  • tear down
« Reply #72 on: June 06, 2012, 06:10:35 AM »
Nice Bart.  How do you like them?  I am hoping they will be a nice compromise between clubmans and superbike bars.
Offline tweakin
  • tear down
Re: 78 cb750F Monkey Trainer "minor update"
« Reply #73 on: June 08, 2012, 05:32:15 PM »
Moved the taillight set up back a bit.  Really happy with the led, has integrated turn signals and pulsing stop.  Made up a bracket out of aluminum to move the taillight / license plate back about two inches, fills up the rear cowl nicely now.
Finished up the gauges added led's to the indicator lights and led strip inside the gauges.  Picked up some billet mirrors to complete the front end.
My battery showed up tonight.  all I have left is to wire the front end bleed the brakes and fire it up...
« Last Edit: June 09, 2012, 04:55:51 AM by tweakin »
« Reply #74 on: June 08, 2012, 08:07:37 PM »
Sweet shots!  Grab a video of that fire up!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1978 Honda XL100
1983 Honda CX650T
1995 Honda VFR750
2015 KTM 200 XC-W
1963 Suzuki T10
