Author Topic: brandEn's K4  (Read 325963 times)
Offline tweakin
  • tear down
Re: La Flama Blanca aka The K4 - painting the tank... AGAIN.
« Reply #75 on: January 18, 2013, 11:52:30 AM »
Glad my new little project got you motivated to dive back into La flama blanca...  You know I will be following.  We need to knock down some IPA's and BS about the builds.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #76 on: January 18, 2013, 06:02:36 PM »
When?  ;D
Offline brandEn
« Reply #77 on: January 18, 2013, 06:50:20 PM »
When?  ;D
your late! Just got home from Tiges....haha
 8)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #78 on: January 18, 2013, 09:01:14 PM »
 8)
Dam!
Hope they where good.
Offline tweakin
  • tear down
« Reply #79 on: January 19, 2013, 07:13:53 AM »
 8)
Dam!
They are always good Jim, we even mentioned we wished you were there...
Offline MikeKato
  • Milwaukee WI
    • TCB true life stories
« Reply #80 on: January 19, 2013, 02:49:15 PM »
When talking about the Silver/Blue color scheme.... I found this one on the facebook "Honda CB 750 four" page and it's such a beauty ! A little nicer seat and that would be 10/10 in my book !
I know cameras can play tricks but I give up. How does the kickstart and oil tank show up on the left side of the bike in that pic? Smoked a bowl and stood on my head but it still didn't look right.
« Reply #81 on: January 19, 2013, 02:56:41 PM »
Mirror image..... ;)
Offline brandEn
« Reply #82 on: January 19, 2013, 02:59:30 PM »
Yup, the Honda badge is backwards too.
« Reply #83 on: January 19, 2013, 07:30:02 PM »
 Where the hell is Jimmy ? ..hasnt been by the shop in a while...
Offline brandEn
« Reply #84 on: January 31, 2013, 12:53:27 PM »
So today I spent a little time getting ready to close the cases. I got my APE HD main bearing studs installed. I also received the rest of my O-rings, new crank bearings, HD cam chain, and needle bearings. Got all of it installed and then snapped a few new pictures. The only thing I am waiting on now is the chain oiler plug from 754 and some new hardware from Bolt Depot. Once I get those it will just be a matter of finding the time.
« Reply #85 on: January 31, 2013, 02:22:05 PM »
Do you work nights or something? I had to sit on my @$$ for 8 hours at work while you got isht done on your bike.  ::)
nice work  8)
Offline brandEn
« Reply #86 on: January 31, 2013, 02:28:08 PM »
YUP. Four ten hour shifts. 9:15pm to 7:15am = HELL.
Offline SF
  • I burn gas very well
« Reply #87 on: January 31, 2013, 05:34:41 PM »
that motor is coming along nicely. what does a rebuild like yours cost if you dont mind me asking because those parts sound like good quality. have you used the same parts in your last build?
so far i have APE main studs but thats it.
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline brandEn
« Reply #88 on: January 31, 2013, 05:46:49 PM »
Hi SF,
rebuilding the motor is not cheap at all. I am using many of the same parts as my other build. Just in the lower end I will have over $500 in new parts
Crank bearings about $110
Roller bearings about $150
Primary Tensioner about $100
Primary Chains about $100
APE main studs $70
HD cam chain $40
misc o-rings and seals about $30 ish I think.
I hate spending money on this stuff but its all necessary for my build because it was high mileage and pretty worn. Many people just put new chains and tensioner in and call it good. The top end is where the big money gets spent just in machining costs alone.
Offline SF
« Reply #89 on: January 31, 2013, 06:14:45 PM »
is there a shop/store that you do one stop shopping or do you look for spicific part mfg's? and order from them?
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
Offline iron_worker
« Reply #90 on: January 31, 2013, 06:23:14 PM »
Sweet!
Once my parts get back from Wisconsin (CycleX) I'll be in the same boat! I'm pretty stoked to put it all together.
And you're definitely right about it not being cheap. Wowzer.
A question: Do you use anti-seize or some type of lubricant on any of the bolts before torquing? Do you put thread locker on anything? What about gaskets ... do you put them on dry or with some sealant?
IW
« Last Edit: January 31, 2013, 06:25:15 PM by iron_worker »
Offline brandEn
« Reply #91 on: January 31, 2013, 06:25:24 PM »
Personally I haven't found one stop shopping. I use Genuine Honda parts when I can. For aftermarket or Hi-Po stuff I get everything from vendors I trust. Cycle-X, APE, Dynoman, Z1 Enterprises, Yamiya, just to name a few.
Offline brandEn
« Reply #92 on: January 31, 2013, 06:31:49 PM »
Sweet!
IW
The Main studs I used some loctite per the directions. For the rest of the case bolts I will use a bit Three bond on the threads per the Hondaman book.
As for gaskets, I am no authority on the subject and its a debated topic with many different opinions. On my F3 high compression motor I have been chasing engine leaks since the rebuild and have found Cometic head, base, and cam cover gaskets coated with Gasgacinch to work for me the best. For the engine covers I used OEM gaskets with no sealant and so far so good.
« Reply #93 on: January 31, 2013, 06:34:51 PM »
Dammit, now I'll have to start on my 'other' bike too!
What are you getting from Bolt Depot?
Which roller bearings are you replacing?
Boys, as far as BrandEn's list goes that's just a good starter. Dig deeper or go home   ;D
Offline brandEn
« Reply #94 on: January 31, 2013, 07:08:32 PM »
Yea that is a cheap bottom end rebuild!
From Bolt Depot I ordered new case hardware. The bolts I pulled from this engine are way to corroded. I didn't get Honda flange bolts cuz they want to much for em.
I replaced the two needle bearings in the clutch hub
Offline tweakin
  • tear down
« Reply #95 on: January 31, 2013, 07:29:18 PM »
Looks good B.
@ flybox.  He doesn't sleep,  then goes and works on planes.  Ha ha :o
Offline SF
« Reply #96 on: January 31, 2013, 07:37:21 PM »
thanks for the info. much appreciated
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
Offline brandEn
« Reply #97 on: January 31, 2013, 07:41:18 PM »
Looks good B.
Yup.
haha
Offline brandEn
« Reply #98 on: January 31, 2013, 07:41:30 PM »
you bet
Offline brandEn
« Reply #99 on: February 01, 2013, 03:21:30 PM »
One more piece to the puzzle got installed today.
The 754 chain oiler plug.
THANKS FRANK! I took some pictures for you.
 ;D
I thought about installing it with some Hi-Temp RTV on the threads but it was such a tight and perfect fit I don't think its really necessary. I just lubed the o-ring with engine oil.
