Author Topic: brandEn's K4  (Read 181065 times)
Re: La Flama Blanca aka The K4 - painting the tank... AGAIN.
« Reply #376 on: June 16, 2013, 12:35:07 PM »
Depending on the epoxy UV stability unpainted carbon fiber is not recommended due to the heat it absorbs in bright sunlight and potential issues with heat and UV breaking down the epoxy. Not sure the reduction is serious or not but painting is recommended. Dark colored paints will just have carbon heat ifssues as well. Carbon kevlar wings in full size and models aircraft are painted light colors to help with this... fwiw...
Ever see hexcel Texalium, an aluminum deposited fiberglass cloth that is decorative in nature and comes in various colors, blue, gold, red, etc. It is stiff material and is best used on parts without complex compound curves. It can be used to create some cool parts.
ebay has a porsche rear panel of the red used between the tail lights of a race car.
It is harder to find now. Sold for about 18/sq yd and is usually a 6 ounce cloth with a carbon fiber twill like weave.
« Last Edit: June 16, 2013, 12:48:51 PM by RAFster122S »
Offline Godffery
  • Godffery's Garage
« Reply #377 on: June 19, 2013, 09:26:06 AM »
Look'n REAL good man!
Offline andrewk
  • doin' it.
« Reply #378 on: June 19, 2013, 04:06:15 PM »
What are you doing for a fork brace?
You're going to have a pair of classy bikes there man.  That motallana fender is the cat's ass- will have to consider it for my K3.
Offline brandEn
« Reply #379 on: June 19, 2013, 04:08:53 PM »
Thanks!
Gonna get a Tarozzi brace.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #380 on: June 19, 2013, 05:05:11 PM »
Branden,
You might wanna have a look at these
http://www.7metalwest.com/motorcycle_parts.html
Offline Doctor_D
« Reply #381 on: June 19, 2013, 07:38:04 PM »
I'll let you know how the 7 West fenders look when I get mine.  I have an aluminum front fender on order.
Take care,
David
1978 CX500
1971 Norton Commando
Offline brandEn
« Reply #382 on: June 19, 2013, 08:47:19 PM »
Nice Jim. Thanks, I haven't seen those before.  I have a decision to make. I will have to think about this one for a bit.
David let me know when you get that thing mounted I would love to check it out.
Offline brandEn
« Reply #383 on: June 20, 2013, 08:28:26 AM »
Anybody have pics of how they modified the rear brake stay (arm as the manual call it)  to fit around a wider rear tire?
Anybody made a custom stay?
Offline Doctor_D
« Reply #384 on: June 20, 2013, 10:50:48 AM »
I made a custom stay out of box section 6061 alu.  I could see doing it with 2024 billet/barstock to decrease the width further.
Something like this http://www.onlinemetals.com/merchant.cfm?pid=13372&step=4&showunits=inches&id=1000&top_cat=0 would likely work.
Take care,
David
1978 CX500
Offline brandEn
« Reply #385 on: June 20, 2013, 01:41:08 PM »
What size rear do have? Did you bend or shape it to fit around the tire?
« Reply #386 on: June 20, 2013, 02:53:44 PM »
you know what they say brandEn.  Size Matters!  ;D
how big are you thinking?
no mods to my stay w/ a 13/90-16
"This is my CB. There are many like it, but this one is mineā€¦"
Offline Doctor_D
« Reply #387 on: June 20, 2013, 03:40:47 PM »
Mine didn't have to be modified, but I went with a stock sized tire/rim.
The 2024 bar is stiffer and stronger than my 6061 box, and would give you another 1/4 to 3/8 inch of clearance.  Round the ends, drill some "speed holes" in it, polish it up, and it should look pretty nice.
Take care,
David
1978 CX500
Offline Nycepop
« Reply #388 on: June 20, 2013, 04:05:52 PM »
I do it, to put an Avon roadrider in 150/70*18
I build that
Offline brandEn
« Reply #389 on: June 20, 2013, 04:22:00 PM »
Yup, I already have my 130 80 18 mounted and the stay won't fit.
That's a great idea but I don't have a straight shot. I'm gonna have to put a spacer on the rear mount and figure something out for the front.
I build that
This is great as well. Thanks for the pictures!
How did you flatten the ends of the round stock?
Offline brandEn
« Reply #390 on: June 20, 2013, 04:24:31 PM »
Well I was able to bend my stock stay and get it to fit. It will work but I don't think it will be my permanent solution.
Offline Nycepop
« Reply #391 on: June 20, 2013, 04:36:34 PM »
I didn't flatten ends, I just have to weld two small parts
look
And after grinding and sandblast
I hope that can help you ;)
Offline brandEn
« Reply #392 on: June 20, 2013, 04:43:45 PM »
Thank you. It definitely helps!
« Reply #393 on: June 20, 2013, 04:56:40 PM »
You could even braze them on and be strong enough if you don't have welding capabilities.
Offline brandEn
« Reply #394 on: June 21, 2013, 10:22:54 AM »
Well since we are on the subject does anybody have any DIY solutions for making one of the brake adjuster arms? I was thinking of threading some round stock maybe...
« Reply #395 on: June 21, 2013, 11:11:42 AM »
Carbon fiber arrow shaft with polished aluminum sleeves on the ends epoxied on. The threaded insert on one end can be used to adapt to one of the end and the other fabbed up out of rod and bar stock.
Offline Flying J
« Reply #396 on: June 21, 2013, 04:10:40 PM »
When you get on the brake hard dont you think the arm will flex? Can you weld a mounting further out on the swing arm? I know it would be a pain to weld on a new one and have to re coat the arm.
« Reply #397 on: June 21, 2013, 04:16:07 PM »
You could weld a round rod to the tire side of the brace to make it even stiffer after the bend if you have enough clearance.
Offline brandEn
« Reply #398 on: June 21, 2013, 04:58:24 PM »
Well I suppose it could flex now that you mention it. I don't think that will make it unsafe just maybe not as efficient ? I will figure something out. I think I would rather make a new arm then relocate the bracket.
Offline brandEn
« Reply #399 on: June 22, 2013, 04:37:08 PM »
Tore into the oil pump tonight and everything looks to be in great shape except the mating surfaces of the rotors. Hondaman's book mentions inspecting these and said that some damage is normal but any more than 5% of the surface and replace. Well mine are way more than that. Anybody got an oil pump or parts to spare?
