Author Topic: brandEn's K4  (Read 184185 times)
Offline tweakin
  • tear down
Re: La Flama Blanca aka The K4 - painting the tank... AGAIN.
« Reply #750 on: November 05, 2013, 06:31:23 PM »
Awesome B...  Only thing missing is the video ;)
You know my thoughts on the fender.  Maybe some IPA's in the near future so I can hear it and see it move.
Offline Godffery
  • Godffery's Garage
« Reply #752 on: November 06, 2013, 08:56:18 AM »
Thanks for the tips everyone.
Godffery I really like that option. You think there is a way to do that but space it down closer to the tire instead of mounting the fender directly to the fork brace?
Perhaps you could use some standoffs (basically a short peace of tubing) as a spacer between the fender & brace, then longer screws to attach them.
« Reply #753 on: November 06, 2013, 03:20:22 PM »
I thought the same thing, maybe sculpted out of rubber or polyurethane to give some vibration resistance.... ;)
Offline brandEn
« Reply #754 on: November 06, 2013, 03:41:01 PM »
Thanks for the tips. I am thinking of options now.
Offline brandEn
« Reply #755 on: November 08, 2013, 03:39:58 PM »
Will bigger slow jets help with popping on decel? I have my airscrews only 1/4 turn out from 1/2. Bike seems to like 1/2 turn better. I have the stock size 40 installed. So 42's?
Offline brandEn
« Reply #756 on: November 09, 2013, 04:50:14 AM »
Anyone?
Offline cheftuskey121
  • Super Newbie
« Reply #757 on: November 09, 2013, 05:04:20 AM »
I have no concrete evidence or experience but it seems logical :D
« Reply #758 on: November 09, 2013, 06:23:26 AM »
Yes.....well maybe, cause is lack of back pressure, my K4 is similar with Action Four exhaust.
Another cause could be you that you are running lean? Good read here....
http://forums.sohc4.net/index.php?topic=108153.0
Offline tweakin
  • tear down
« Reply #759 on: November 09, 2013, 06:28:03 AM »
That might help.
Have you sealed up all the exhaust joints?  Often decel pop is caused by exhaust leaks.  Take it to Tower and put it on the dyno would be your best bet B.
« Reply #760 on: November 09, 2013, 06:33:34 AM »
I also run a 4-1 MGP pipe that pops on decel but is it an open (non-baffled) pipe.   I'm not sure if you can outright avoid it.
« Last Edit: November 14, 2013, 07:52:31 AM by CB750 Cafe Racer Fan »
Offline Godffery
  • Godffery's Garage
« Reply #761 on: November 09, 2013, 07:50:50 AM »
If the Mixture screws are only 1/4 turn out (witch leans the mix) then increasing the slow jet size doesn’t seem necessary? If you want to go richer, back the screws out. Stock is somewhere in the rang of 1&1\2 turns out.
Is your timing set to stock specks or advanced?  I've never had a bike with NON STOCK EXHAUST that would behave using the stock timing setting.
Offline brandEn
« Reply #762 on: November 09, 2013, 08:04:41 AM »
Thanks for the link.
Figure I will at least try them. I didn't even think about back pressure causing it.
Offline brandEn
« Reply #763 on: November 09, 2013, 08:07:03 AM »
Wait, I thought turning the screws in made it more rich ....
Pamco ignition with stock advance.
Offline brandEn
« Reply #764 on: November 09, 2013, 08:09:43 AM »
I have not sealed any of the joints. I suspect it's a carb tuning issue. It's not severe popping at all, just wanna play around to see if I can eliminate it.
Offline Doctor_D
« Reply #765 on: November 09, 2013, 11:03:56 AM »
Happy birthday, dude.
Take care,
David
1978 CX500
1971 Norton Commando
Offline brandEn
« Reply #766 on: November 09, 2013, 11:25:00 AM »
Thanks!
« Reply #767 on: November 10, 2013, 12:03:55 PM »
Richen it just a little. Mixture screw first.  Of you're out of adjustment range, then go up in pilot size.
The popping on decel is likely from accumulated fuel in the exhaust system lighting off.  Which can occur from multiple stimulus.
- Leaks in the exhaust system can provide oxygen to enable the unburnt fuel to ignite with an ember from the piston chamber.
- If all the slides don't close evenly, some cylinders may get more fuel than others and pass that charge unburned into the exhaust.  (Carb sync is needed.)
Leaning the idle mixture (turn screw out on Non-PD carbs) of the offending out of sync carb, should help abate the fuel buildup in the exhaust when the slide is in it's closed position.  This is a diagnostic, not a fix of the source problem of out of sync carbs.
If carbs are in sync and there are no exhaust leaks, popping on decell is caused by a too lean mixture (normally caused by altering the inlet duct).
If the idle mixture is too lean, the cylinder will not fire the mixture at all and shove the lean mixture out the exhaust port unburnt.  The rider can't tell, because he isn't asking for ANY power.  However with enough exhaust cycles, there is enough fuel to ignite in a 4 to1 collector with an ember from any of the cylinders.  Pop.  The longer the deceleration time and the leaner the mixture, determines just how much popping occurs.
So, if the mixture is kept rich enough that the mixture fires even with no power being produced, no fuel collects and no popping occurs.
Popping can have more than one cause and the correction must fit the cause.
« Last Edit: November 11, 2013, 08:03:00 AM by flybox1 »
Offline brandEn
« Reply #768 on: November 10, 2013, 12:08:22 PM »
From my understanding popping on decel is a lean condition. So I want to enrichen it up I believe...
or am I mistaken?
Offline Godffery
  • Godffery's Garage
« Reply #769 on: November 10, 2013, 06:19:00 PM »
Yes, richer.
« Reply #770 on: November 11, 2013, 08:03:41 AM »
my bad, you're right.
corrected the post above and inserted the TT post that keeps me straight...
Offline SOHC Digger
  • I'm not an
« Reply #771 on: November 14, 2013, 05:38:17 AM »
Wow, some good info here!
Offline brandEn
« Reply #772 on: November 16, 2013, 03:52:32 PM »
I had to order new oil and neutral sensors as well as side cover gaskets and Honda float valves. Got all that stuff installed as well as a set of #42 idle jets. Bike seems to idle a bit better already. Hopefully the clean up I did on the new gaskets stop the damn oil leak I had. So far the carbs haven't leaked a drop. I also ordered this sweet float gauge off ebay. Got this from the same guy I got my SS brake pistons from. Great service and products and even came with instructions. This tool makes adjusting the floats so much easier!
« Last Edit: November 16, 2013, 04:38:20 PM by brandEn »
  • Super Newbie
« Reply #773 on: December 02, 2013, 06:29:32 PM »
I have that same float adjuster tool. its great for those carbs. how's the bike? haven't seen an update in a good bit now.
Offline tweakin
  • tear down
« Reply #774 on: December 02, 2013, 07:13:22 PM »
I think the bike is done and pics don't do it justice.  I think its ready for the BOTM nod... ;)
