Author Topic: Black Engine  (Read 6831 times)
Offline Dusthawk
  • Dusthawk & Rita IFO Phils Cafe, bestest Breakfast!
    • My MySpace Place
Black Engine
« on: June 03, 2006, 11:48:49 AM »
I was down at Denny's last night talking to a couple guys about a ride tomorrow and about my bike, when he saw my black wrinkle engine he said uh-oh, you'll have probs with that engine because it is a Black Engine.  Something to do with the cam siezing or something? Has anyone heard of this?
Jeff
1971 Honda CB750 K1 Chopper A.K.A. Rita
Build Thread: http://forums.sohc4.net/index.php?topic=86383.25
upperlake04
Re: Black Engine
« Reply #1 on: June 03, 2006, 11:54:22 AM »
Jeff - the 78 750Fs had black engines. They had problems but not because of their color.
Offline Gordon
  • 750K1, 550K2
Re: Black Engine
« Reply #2 on: June 03, 2006, 11:56:44 AM »
Not quite sure I understand. ???  Is he saying there's a certain engine model that has cam problems and just happens to be black, or that painting the engine black would cause some kind of problem?
P.S.  Just saw upperlake's post, so that makes a little more sense.  I didn't realize the 78 F's had that problem.
Offline scondon
  • Mmmm......tasty bugs
Re: Black Engine
« Reply #3 on: June 03, 2006, 12:13:04 PM »
Jeff
77-78 750F engines(black) have a redisigned head that is not like the other 750's. The valves and guides wear out much faster.
Offline Dusthawk
    • My MySpace Place
Re: Black Engine
« Reply #4 on: June 03, 2006, 12:21:09 PM »
Sorry about that, I could have been more precise. :-[ He said that the early 750's had an oil problem up near the cam and the ones that had a problem were the ones that were painted black from the factory. I didn't really understand as well but the way I understood it was the engines slated for black paint somehow had different oil passages or something. Thats why I'm posting the query, I'm baffled. He did say that he had an early 750 with a painted black engine and his cam froze up and that he heard through whatever grapevine that he had heard of others with the problem.
I wish I could be more precise but thats all I have.
My engine number confirms it is a '71 and it is wrinkle black, so I think it came stock like that.
This is me scratching my head ???
Jeff
Offline scondon
Re: Black Engine
« Reply #5 on: June 03, 2006, 12:25:00 PM »
To my knowledge only the 77-78 SOHC came with stock black paint.
Re: Black Engine
« Reply #6 on: June 03, 2006, 12:32:32 PM »
Perhaps the issue is not the color, but the thickness of the paint.  If it is thick, it acts as an insulator preventing the heat from the metal fins to be transferred to the passing air.
The color black radiates and absorbs heat readily, but paint itself is an insulator.  Multiple layers or high buildup thickness can restrict heat transfer.
Wrinkle finishes can be thick depending on how it was applied.  Are you headed for the high desert?  Are you using synthetic oil that breaks down at higher temps?
No 71 750s came from the factory with black engine paint.  Only the 77-78 750F had that and it wasn't wrinkle finish.  Their valve geometry caused excessive wear.   Top cam oiling problems usually stem from excessive gasket sealant breaking away and clogging the oil restrictors going to the cam.
Re: Black Engine
« Reply #7 on: June 03, 2006, 03:01:32 PM »
Jeff
For Christsakes that is an absolutely retarded statement on the part of that individual. I have (had) a comparison between sand blast, bead blast and flat black surfaces heat shedding abilities published in RoadRacing World from a million years ago. The thin, flat black surface shed heat the best. Look at Harley's with wrinkle cases, cylinders  and heads. While they might not perform they don't seize.
Offline scondon
Re: Black Engine
« Reply #8 on: June 03, 2006, 03:54:18 PM »
   Say it like ya mean it Mike :D :D :D :D
   I also heard this from someone when I first started biking again. Something about small passages restricting flow. I've taken apart '78 750F(black motor), '78 750K, and '76 750F top ends and can see no difference in the oil feed to the cam. They all had one feed,with a oil restrictor, to each cam tower  . Did earlier engines have two feeds to each tower? Were the oil restrictors under the towers not on earlier engines?
   I've just come to the conclusion that people were guessing as to why these "black motors" were burning up and the "oil problem" thing is a myth that got passed around too much. I agree with TT that care must be taken not to block the oil restrictors when rebuilding(fried cam taught me that one). I haven't heard of it being a problem on an unmolested stock motor though.
   I would like to know if anyone can shed more light on this "oil problem" that I have heard so often.
Offline Jonesy
  • Shop Rat
Re: Black Engine
« Reply #9 on: June 03, 2006, 04:19:23 PM »
I thought HondaMan posted something about the changes made to the CB750 valvetrain in the mid-70's and the changes caused the rockers to wear out faster....
For heat radiation, black is the best color.
Offline Bob Wessner
  • "Carbs Suck!"
Re: Black Engine
« Reply #10 on: June 03, 2006, 06:01:07 PM »
I know, I know, everyone says that black paint actually helps cool the engine, who am I to dispute that. However, darned if it doesn't seem counter-intuitive.  :-\
Re: Black Engine
« Reply #11 on: June 03, 2006, 06:11:55 PM »
I dunno guys, could be something in it, did you all know that more people die in red cars than any other color? ???
Re: Black Engine
« Reply #12 on: June 03, 2006, 06:15:52 PM »
Damn right Sean. The later oil feeds were instituded to prevent oil problems secondary to 1, very small feed hole. The oil jet would be much harder to choke than than that silly little hole.
Re: Black Engine
« Reply #13 on: June 03, 2006, 06:17:10 PM »
Christ I got more tickets in a bright yellow car than any other I've owned. ???
Offline scunny
  • don't call me expert
Re: Black Engine
« Reply #14 on: June 03, 2006, 06:23:45 PM »
red cars are faster, same as a company vehicle is faster, and can rev higher in all the gears than your own  ;D
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Re: Black Engine
« Reply #15 on: June 03, 2006, 06:42:06 PM »
  That USA policy son.....all company cars must have a rev limiter set 1.000RPM above OEM standards. #$%*....things just couldn't get done otherwise. ;)
Re: Black Engine
« Reply #16 on: June 03, 2006, 06:50:08 PM »
No seriously guys, (geez, that sounds strange coming from me.......) more people die in red cars than any other color!  :o
Re: Black Engine
« Reply #17 on: June 03, 2006, 06:53:57 PM »
Because nobody makes minivans in red Terry. :D ;D
Re: Black Engine
« Reply #18 on: June 03, 2006, 07:10:47 PM »
No Mike, but there is actually a reason! Keep guessing.................  ;D
Offline Jonesy
  • Shop Rat
Re: Black Engine
« Reply #19 on: June 03, 2006, 07:23:24 PM »
Aw geez, Bob... You gonna make me dig out my old heat transfer textbook and scribble it all out to prove how it works? ;) ;D
Offline angeldeville
  • You meet the nicest people on a Honda!
Re: Black Engine
« Reply #20 on: June 03, 2006, 09:54:02 PM »
and some people think Hardley's are the best bike ever made, doesn't make em' right just misinformed.
76' cb750f custom
69' cb750 sandcast
69' CT90
Amen Saviour 750 Chopper frame
and enough parts to build about 6-7 more bikes
Re: Black Engine
« Reply #21 on: June 03, 2006, 10:01:51 PM »
Is that a real tat on your leg mate? How about a bigger pic? ;D
Re: Black Engine
« Reply #22 on: June 03, 2006, 10:10:18 PM »
that's my left arm
76' cb750f custom
69' cb750 sandcast
69' CT90
Re: Black Engine
« Reply #23 on: June 03, 2006, 10:33:52 PM »
That's a nice tat mate! ;D
Re: Black Engine
« Reply #24 on: June 03, 2006, 10:39:55 PM »
Jeff
Your friend is out to lunch.
Some "F" engines were anodized black, some guys just painted "K" engines black. The painted ones ran hotter. If you run 10w40 oil AND paint it black, it will wear the cam bearings (and some other top-end parts) faster because of lowered oil viscosity in the head.
That's the whole story.
