Author Topic: Help a newb with what this bike is worth  (Read 5856 times)
Offline BeSeeingYou
Re: Help a newb with what this bike is worth
« Reply #50 on: March 25, 2012, 11:18:40 PM »
Those headers are a funky colour. Is that normal for those pipes?
They look like after market headers and probably single wall pipes so it's not uncommon to see that.  The stock headers are double wall and less likely to do that unless the bike runs lean.
« Reply #51 on: March 26, 2012, 12:23:05 AM »
 It only had to run lean a short while..but people will tell you for the rest of the pipe ..that you are burning up or running lean..
 I used to tell people..Yeah, it ran lean 12 years ago..
 What do they think?.. the color will go back!........................................ Got the pipes on my Beemer red hot..you could see them glowing in the dark...
« Last Edit: March 26, 2012, 08:16:14 AM by 754 »
Offline Rich Halsey
« Reply #52 on: March 26, 2012, 05:14:53 AM »
The pipes are single wall aftermarket pipes. In my experience its hard to keep them from not turning colors, but my experience was with Harleys.
The carbs on this thing were a HOT MESS. All 4 slides were stuck as were all 4 floats. The bowls were downright nasty with varnished fuel and most of the jets were also clogged up. I wasn't sure how well everything would clean up but with an overnight soak in Chem Dip and lots of scrubbing they did. I have a set of indexing bits that I used for nitrous jets that I ran through all the jets and I guess I got lucky. The tank was full of old fuel, but very clean so I just removed the pitcock and cleaned everything out, put some gas in her, reassembled the carbs, put it all back together and pulled the choke and she fired right off. I was pretty happy to say the least.
Thanks again for all the advice and help.
BTW, I paid the man last night and got the title to it !!!
One question, I would like to remove the rack on the back but that is where the turn signals are mounted . Where did they mount to from the factory?
« Reply #53 on: March 26, 2012, 08:14:39 AM »
 2 tabs facing down off the rear grab bar, near the long mounting bolt holes.. if you have the grab bar.
Offline Johnie
« Reply #54 on: March 26, 2012, 09:13:21 AM »
Here is a visual for you...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline bender01
« Reply #55 on: March 26, 2012, 09:44:56 AM »
Congratulations. Nice bike!
75 550 K1
74 750 K4
1968 450 K1 Super Sport
74 750k 836 project
Good luck!
Two Tired Quote !
